Thread: R.I.P.
    Jun 2008
    Default R.I.P.
    Could'a put my ladder anywhere but there he was. It gave me a chuckle.
    Default Re: R.I.P.
    Too funny!
    Did you have your ladder on a deck? That is very dangerous you know. I guess if you keep it steep enough and the deck is dry it is ok but wood can be slippery even when dry.
    Default Re: R.I.P.
    Unfortunately, discovery of these these tragic deaths comes with the job.
    Jun 2008
    Default Re: R.I.P.
    Quote Originally Posted by Bruce King View Post
    Too funny!
    Yes the ladder was on the deck and I do keep it pretty steep. It also has rubber feet to keep it from slipping. The rubber feet also help to prevent shingle damage when I use it to go from one roof level to another.
    Default Re: R.I.P.
    There must be serial killer on the loose!
    Default Re: R.I.P.
    Carry 2 5-in-1 tools with you, they have good stiff blades, or two small pry bars, shove them down between two deck boards and push the ladder feet against them. They will offer a lot of resistance to further slipping on a wood deck (of course the wood has to be running the right way for those to work, however, most wood decks are laid out the right way).
