Results 1 to 17 of 17
10-02-2009, 08:13 AM #1
Items a homeownes should correct before an inspection
I recieved a call from a reporter from my local paper [ for the real estate section] yesterday asking me this question.
It caught me a little ole me [ she called me out of 5-600 inspectors] off guard, some of the first basic things that I thought about were..
Change burnt out light bulbs.
Replace dirty AC filters,
Fix plumbing leaks
Trim trees and bushes around the home
Adjust windows that don't lock or slide properly
Replace batteries in smoke detectors
Make sure all rooms are accessible
If major repairs were made provide the buyer the name and phone # along with copy of the bill from the contractor
If your local paper called you what would you suggest?
Similar Threads:Phoenix AZ Resale Home, Mobile Home, New Home Warranty Inspections. ASHI Certified Inspector #206929 Arizona Certified Inspector # 38440
www.inspectaz.com
10-02-2009, 08:21 AM #2
Re: Items a homeownes should correct before an inspection
Well.....Everythihng..........Of course that is not going to happen.
The things to fix if they cannot afford much would be filters, batteries, minor plumbing leaks, bushes, light bulbs and such.
Any of the smaller items like trimming bushes and all is a must. That being for the reason that when the inspector starts writing up the report and everything is negative thru the entire report because it is filled from front to rear with all these little things along with mixed in major concerns the buyers are blown away with so much wrong with the home.
If all the small items are fixed then the report shrinks dramatically and does not look so overall bad.
10-02-2009, 08:23 AM #3
I Don't think thats going to happen...
It maybe hard for the banks to do any of these things. most of the agents can't even get the water or Elec. on
Best
Ron
10-02-2009, 08:50 AM #4
Nows the time to start training them
I can relate to the water and elec on. Mon I had two repos, per the realtor, and listing agent everthing was on.
[ Thank goodness I also had a 5000 sq. ft. 1 yr warrany inspection. ]
1st one no water, come to find out the water company shut it off and would not turn it back on until the previous bill was paid.
The buyer already paid the past bill for the electric to get that turned on.
2nd one,had water, but no electric.
I'm not sure why the elec or water co would not turn it on, at least for the inspection, where it stands now they aren't getting paid for the past bill, and not getting paid for new service.
www.inspectaz.com
10-02-2009, 03:53 PM #5
Remove the cat box from the bathtub and clean up the dog shat from the yard around the foundation area.
10-02-2009, 05:00 PM #6
Put the GFCI's in where they are supposed to be. Almost every house unless it's brand new has missing GFCI receptacles somewhere.
10-03-2009, 07:37 PM #7
10-04-2009, 04:34 AM #8
Just an honest, Truthful, disclosure.
10-04-2009, 05:14 AM #9
10-04-2009, 05:29 AM #10
Install house number on the front of the house where it can be clearly seen from the street! Seconds count especially in an emergency response situation day or night.
How many times have we all had trouble finding a house number that either is not present, installed behind a bush, or on a rock in the garden, or brass or other coloured number that blends in with the house itself.
Also clear around the furnace and remove items from closet so access to the attic is easier.
10-04-2009, 05:53 AM #11
Sellers don't understand how up front disclosure can benefit them.
When the inspection finds a significant condition that's not on the disclosure, and it's one that you figure the seller had to know about, the trust factor begins to diminish rapidly when you don't see it listed on the disclosure. I've seen buyers walk simply because of this. On the other hand, they can be very willing to work with sellers who spill the beans.
10-04-2009, 08:08 AM #12
I had a similar call from a local paper last year. One statement I made to the reporter was highlighted when the article came out. This is it:
Prepare your current home like you would expect your new home to be when you purchase it!
10-04-2009, 09:51 AM #13
10-04-2009, 04:44 PM #14
10-05-2009, 12:17 PM #15
Make sure the gutter downspouts are connected.
10-06-2009, 04:45 AM #16
"and last but not least, go away"
...and take those yapping little dogs with you!
DetroitMatt
10-09-2009, 03:29 PM #17
Super list - I'm going to consolidate it in a Word or Excel file.
