Results 1 to 23 of 23
    Default Insert Your Own Caption for This Pic
    Just for fun. Insert your own caption.
    Default Re: Insert Your Own Caption for This Pic
    I Couldn't Find a Bucket.
    * or a Big Basting Pan
    Its works! Thanks Joe the Plumber, your my hero.
    Colorado Springs, CO
    "It's not leaking so it is not a problem", said the real estate agent.
    Bruce Breedlove
    www.avaloninspection.com
    Ron Bibler's Avatar
    Ron Bibler Guest
    Quote Originally Posted by Bruce Breedlove View Post
    Thats whats this agent said to me when i pointed out the the CSST gas line was going though the air handler for the furnace.
    Best
    Ron
    David Bell's Avatar
    David Bell Guest
    A thousand and one uses for unmatched socks.
    Connecticut
    Owners Ferret prevented me from accessing the plumbers t shirt, in order to evaluate the repair needed at the vent pipe.
    Stopping leaks AND washing clothes at the same time.......that's what I call a win-win situation.
    Nov 2009
    St Paul, MN
    "Yes, I wrapped a rag around the vent pipe to temporarily stop stop the flashing leak from staining the ceiling. The next day I had a license roofer replace the roof. Here's the receipt and a copy of the permit. So what's the problem?".
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    Ken,
    That's Hilarious.
    The Roof Rats Ate The Peanut Butter I Smeared on The Leaks.
    Dec 2007
    Oklahoma
    Honey!! have you seen my underwear?
    Christopher Gorton's Avatar
    Christopher Gorton Guest
    It's only temporary...unless it works.
    Feb 2010
    Long Beach, CA
    Torus configured absorbent textile collectors have been installed at primary and secondary locations of the PVC vent pipe's vertical run where it transitions through the attic suggesting cursory on-site repairs by the occupants and requires further inspection/repair of the pipe’s roof penetration by a licensed roofing contractor.
    Isn’t that how we would write it up?
    Feb 2010
    Long Beach, CA
    Even I got it wrong...
    Torus configured absorbent textile based moisture collectors have been installed at primary and secondary locations of the PVC vent pipe vertical run where it transitions through the attic suggesting cursory on-site repairs by the occupants and requires further inspection/repair of the pipe’s roof penetration by a licensed roofing contractor.
    mathew stouffer's Avatar
    mathew stouffer Guest
    It has been like that for 4 years, it's fine. My client is only looking for big ticket items
    David Bell's Avatar
    David Bell Guest
    The Iraqi plumber in an attempt to stop the water wrapped a Keffiyeh around the pipe and prayed to Allah to stop the rain.
    "Hey What? One, black, one white... they match my socks. What's YOUR problem?"
    "The Iraqi plumber in an attempt to stop the water wrapped a Keffiyeh around the pipe and prayed to Allah to stop the rain."
    Not funny.
    John Korupp's Avatar
    John Korupp Guest
    Looks like a candidate for that web site: "There! I fixed it!"
    David Bell's Avatar
    David Bell Guest
    Not funny.
    Why? What if he was Polish or Italian or Puerto Rican? It really wouldn't have worked since they probably don't know how to tie Keffiyehs. Which by the way is what the picture looked like to me.
    Corpus Christi, TX
    Wasted strapping on pipe. Remove and replace with upper sock. Lower sock presents as adequate to stop water from minor leak at flashing. Use strap somewhere else. Insulation dry now. No harm done.
    - Paul Fix
    William Brady's Avatar
    William Brady Guest
    the real estate broker said "you can't be right I've never heard of it"
