Results 1 to 12 of 12
    Default Smallest inspection?
    This was a military relocation job. A new apartment building next door to the base. 472 sq ft.
    It's a functional layout. I would add a bedroom door.
    I checked the building exterior, roof, garage, storage lockers, common areas, and found a few blemishes in the unit. Kept busy and wrote a nice report.
    What was your smallest inspection?
    Default Re: Smallest inspection?
    It was a 750 sq. ft bungalow type house. However, with the number of defects I found, you'd have sworn the house was three times are large.
    Ron Bibler's Avatar
    Ron Bibler Guest
    A 25 foot Boat... In the water at Ventura harbor... It had termites in the deck and around the windows. Nice little boat...
    Best
    Ron
    Knoxville, TN
    600 SF condo
    My Wallet !
    May 2007
    Tyler, TX
    The wallet notwithstanding....
    800 sf was the smallest house I've inspected
    Bruce Thompson, Lic. #9199
    www.TylerHomeInspector.com
    Quote Originally Posted by JB Thompson View Post
    Oh House 1014 sq ft. ( turns out another HI was flipping it called to " Discuss The Report"
    Mesa AZ
    I've done a lot of park model/ mfg homes under 400 sq ft'
    After apx 30 min I'm wondering what to do next
    www.inspectaz.com
    May 2007
    Tyler, TX
    Quote Originally Posted by Dan Harris View Post
    After apx 30 min I wondering what to do next
    I can't do anything in 30 min. It still has appliances, HVAC, electrical....
    New Mexico
    There are a bunch of 718 square foot houses in one area of town. They're kind of a pain, though. The furnace is in the crawl space, and the crawl in general is not easy. We have some senior condos that are really nice to inspect. No roof, no crawl. If I didn't have anyone asking me questions I could be out of there in 45 minutes.
    Mesa AZ
    They are pretty cut and dry,
    Interior 10-15 min
    Turn the AC on, Check the stove and frig, no dishwasher
    Turn the kit and bath faucets on and check the 10 - 12 outlets
    Poly bute Yep,
    Window leaks, yep,
    water damaged flooring in bath , yep
    ceiling stains , yep
    Exterior
    Walk the exterior - 5 min
    Check exterior elect panel with 5 or 6 breakers, , and pedistal another 5 min.
    Crawl space-- 10 min
    remove 4- or five skirting panels
    write up recommend temite inspector, tighten blocking
    Roof- 5 min,
    yep bad, have roofer fix or replace , and seal all vents, replace the sun damaged ski lite,
    www.inspectaz.com
    Nov 2009
    St Paul, MN
    I did a 300 sq ft efficiency condo. One room with a 3/4 bath. Not even a closet in the place. Association supplied heat and water. No laundry. Had it's own electrical panel. Two windows. It took about 30 minutes.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
