    Chicago
    Default HI Artography - Abstract / What is it?
    Guess what this is from.
    Mike Lamb
    Inspection Connection, Inc.
    Default Re: HI Artography - Abstract / What is it?
    Inside view of damaged clay pipe.
    Chicago
    Close enough. Clay liner in a brick chimney. If you look carefully, there's a vent in there that has been pushed way too far into the liner.
    Mike Lamb
    So, do I get a signed Lithography?
    Mar 2008
    Charlotte NC
    That is awesome! I thought it was a black hole about to swallow Detroit, Pittsburgh and Chicago. Truly better than most of what you see in art galleries.
    Chicago
    Thanks, Vern.
    No lithograph, Rick. If you give me an address you can get a free 4" x 6" with a street value of 13 cents. When I die I expect the value to double.
    Mike Lamb
    I would have said a rotted disease riddled toilet that you flushed just as you dropped your cell phone in it.
    It does look like a cell phone in there
