Results 1 to 33 of 33
    Capistrano Beach, CA
    Post Inspection Related Acronyms
    I am looking for a list of all inspection related acronyms that people put in their post.
    Can you please help me with this?
    Inspection Referral SOC
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Default Re: Inspection Related Acronyms
    PITA
    Personally Irritating, Tenacious Antics
    I'll contribute the core items:
    GFI, GFCI, AFCI, AAV air admittance valve, OSB, TPR, TPRV, PRV, HVAC, AC, HRV, heat recovery ventilation
    SOP, COE, ASAP
    OCPD-Over current protection device
    FPE-Federal Pacific Electric
    IRC-International Residential Code
    IPC-International Plumbing Code
    IBC- International Building Code
    NEC- National Electrical Code
    Thank you!
    Keep posting them as you think of them.
    Sincerely,
    Brian Hannigan
    Chicago
    AHJ - Authority Having Jurisdiction
    DWV - Drain, Waste and Vent
    OSB - Oriented Strand Board
    POS - Piece of Sh*t
    Mike Lamb
    Inspection Connection, Inc.
    FPE is "Fire Producing Equipment"
    Mar 2008
    Charlotte NC
    PCO- Pest Control Operator
    AMV- Adhered Masonry Veneer
    New Mexico
    PACM, EIFS, PEX, DHW
    SEC service entry cables or conductors
    EGC equipment grounding conductor
    CB circuit breaker, and there are many more in the NEC
    CEC is the Canadian Electrical Code
    CPSC - Consumer Product Safety Commission
    AWG - American Wire Gauge
    UL - United Labratories
    AFUE - Annual Fuel Utilization Efficiency
    CMU - Concrete Masonry Unit
    ANSI - American National Standards Institute
    ASTM - American Society for Testing Materials
    PVC, CPVC, ABS Plumbing
    Come on Jim, are you going to make me look them up?
    Sincerely,
    Brian Hannigan
    Mar 2012
    North Central Texas
    PACM - presumed asbestos-containing material (never heard this actually used by an HI)
    EIFS - exterior insulated finishing system (see also POS)
    PEX - cross-linked polyethylene (see also POS)
    DHW - domestic hot water (never heard this actually used by an HI)
    Texas Inspector
    http://www.texasinspector.com
    Mar 2012
    North Central Texas
    Should be Underwriters Laboratories
    Polyvinyl chloride, chlorinated polyvinyl chloride, acrylonitrile-butadiene-styrene
    Texas Inspector
    Aug 2012
    Rock Hill S.C.
    MWBC- multi wire branch circuit.
    WH- water heater
    LVL- laminated veneer lumber
    PT- pressure treated
    Jan 2013
    British Columbia
    PITA
    I thought PITA was Pain In The A$$
    Checkpoint Home Inspections
    www.checkpointinspections.ca
    Quote Originally Posted by Doug Campone View Post
    With my way, when I call someone a PITA I have not violated forum rules.
    Mar 2012
    North Central Texas
    Quite right. Like POS = probable obnoxious situation
    Texas Inspector
    WETT - Wood Energy Technology Transfer (Inspection organization in Canada used to inspect wood fireplaces, wood stoves)
    NFPA - National Fire Protection Assc.
    OSHA - Occupational Safety and Health Administration
    CDC - Centres for Desease Control
    EPA - Environmental Protection Agency
    One other thing... I would never use the acronym in a report I would use the proper name as most readers of a report would not likely be familiar with the acronym.
    New Mexico
    I figured someone else would come up with the answers.
    TPO = Thermo-Plastic Olefin - PVC (yet another acronym) roofing material that is used a lot here on low slope roofs.
    EER - emergency egress requirement - may have been mentioned already
    Feb 2013
    FLORIDA
    CBS-Concrete Block and Stucco.
    Mar 2008
    Charlotte NC
    FVIR- Flammable Vapor Ignition Resistant
    Waterloo, Ontario
    NFG = Not Functioning Good
    HVAC = Heating Ventilation and Air Conditioning
    IR = Infrared
    EPS = expanded polystyrene
    XPS = extruded polystyrene
    - - - Updated - - -
    HI = Home Inspector
    PE or P.Eng. = Professional Engineer
    Jan 2011
    Guelph,Ontario
    NFG,I have an other meaning,but can not post it.
    Peoria Arizona
    AAV(s): Air Admittance Valve
    ABS: Acrylonitrile Butadiene Styrene
    A/C: Air Conditioning
    AC: Alternating Current
    ADA: Americans with Disabilities Act
    AGA: American Gas Association
    AHJ: Authority Having Jurisdiction
    ALUM: Aluminum
    AMP: Ampere, Ampacity
    AMPY: Ampere
    ANT: Antenna
    ASB: Asbestos
    AWG: American Wire Gauge
    BKR: Breaker
    BRKR: Breaker
    BO: Building Official
    BTU: British Thermal Units
    BUR: Built-up Roof
    CFM: Cubic Feet per Minute
    CPVC: Chlorinated Polyvinyl Chloride
    CSST: Corrugated Stainless-Steel Tubing
    DBT: Drybulb Temperature
    DC: Direct Current
    DWV: Drain, Waste, Vent
    EVAP: Evaporator
    EXH AIR: Exhaust Air
    FVIR: Flammable Vapor Ignition Resistant
    GALV: Galvanized
    GFCI: Ground Fault Circuit Interrupted
    GFI: Ground Fault Interrupted
    HVAC: Heating, Ventilating & Air Conditioning
    J-BOX: Junction Box
    MAX: Maximum
    MIN: Minimum
    PB: Polybutylene
    PEX: Cross-linked Polyethlene
    PRV: Pressure Relief Valve
    PSI: Pounds per square inch
    PSIG: Pounds per square inch gage
    PVC: Polyvinyl Chloride
    RMC: Rigid Metal Conduit
    TJI: Manufactured I-joists
    TPR: Temperature & Pressure Relief
    UL: Underwriters Laboratories Inc.
    Do folks really use acronyms like this when you write your reports? If so, why?
    Peoria Arizona
    Scott,
    Brian was looking for acronyms that people put in their post. (he did not say report) A lot of the mentioned acronyms are common ones.
    In my report, the first time I use an acronym in a paragraph, I will list the acronym and the complete words. Thereafter, I may use only the acronym. Example: PEX (Cross-linked Polyethlene), AWG (American Wire Gauge)
    I also list all acronyms that may have been used throughout the report at the end of the report for further reference.
    Jeff
    Thumbs up Re: Inspection Related Acronyms
    These are great. Thank you all and keep them coming.
    Sincerely,
    Brian Hannigan
  29. #29
    Thanks everyone!
    Here is the cleaned up list I now have. Do you see any corrections or more that you add to this list?
    A/C => Air Conditioning
    AAV => Air Admittance Valve
    ABS => Acrylonitrile butadiene styrene
    AC => Alternating Current
    ADA => Americans with Disabilities Act
    AFUE => Annual Fuel Utilization Efficiency
    AGA => American Gas Association
    AHJ => Authority Having Jurisdiction
    ALUM => Aluminum
    AMP => Ampere, Ampacity
    AMPY => Ampere
    AMV => Adhered Masonry Veneer
    ANSI => American National Standards Institute
    ANT => Antenna
    ASB => Asbestos
    ASHI => American Society Of Home Inspectors
    ASTM => American Society for Testing Materials
    AWG => American Wire Gauge
    BKR => Breaker
    BO => Building Official
    BRKR => Breaker
    BTU => British Thermal Units
    BUR => Built-up Roof
    CB => Circuit breaker
    CBS => Concrete Block and Stucco
    CDC => Center for Disease Control
    CEC => Canadian Electrical Code
    CFM => Cubic Feet per Minute
    CMU => Concrete Masonry Unit
    CPSC => Consumer Product Safety Commission
    CPVC => Chlorinated polyvinyl chloride
    CREIA => California Real Estate Inspection Association
    CSST => Corrugated Stainless-Steel Tubing
    DBT => Drybulb Temperature
    DC => Direct Current
    DHW => Domestic hot water
    DWV => Drain, Waste and Vent
    EER => Emergency egress requirement
    EGC => Equipment grounding conductor
    EIFS => Exterior insulated finishing system
    EPA => Environmental Protection Agency
    EPS => Expanded polystyrene
    EVAP => Evaporator
    EXH AIR => Exhaust Air
    FPE => Federal Pacific Electric
    FVIR => Flammable Vapor Ignition Resistant
    GFI => Ground Fault Interrupted
    HI => Home Inspector
    HVAC => Heating Ventilation and Air Conditioning
    IBC => International Building Code
    interNACHI => International Association of Certified Home Inspectors
    IPC => International Plumbing Code
    IR => Infrared
    IRC => International Residential Code
    J-BOX => Junction Box
    LVL => Laminated veneer lumber
    MAX => Maximum
    MIN => Minimum
    MWBC => Multi wire branch circuit
    NAHI => National Association of Home Inspectors
    NEC => National Electrical Code
    NFPA => National Fire Protection Association
    OCPD => Over current protection device
    OSB => Oriented Strand Board
    OSHA => Occupational Safety and Health Administration
    PACM => Presumed asbestos-containing material
    PB => Polybutylene
    PCO => Pest Control Operator
    PE => Professional Engineer
    PEX => Cross-linked polyethylene
    PRV => Pressure Relief Valve
    PSI => Pounds per square inch
    PSIG => Pounds per square inch gauge
    PT => Pressure treated
    PVC => Polyvinyl chloride
    RMC => Rigid Metal Conduit
    SEC => Service entry cables or conductors
    TJI => Manufactured I-joists
    TPO => Thermo-Plastic Olefin
    UL => Underwriters Laboratories
    WETT => Wood Energy Technology Transfer
    WH => Water heater
    XPS => Extruded polystyrene
    Sincerely,
    Brian Hannigan
    SOP, COE, ASAP
    John, I see a couple in your list that I did not get. I will get them later.
    Sincerely,
    Brian Hannigan
  31. #31
    Mar 2012
    North Central Texas
    Brian:
    While it may be a hair-splitting point to make, most of those are not actually acronyms, but rather abbreviations. The difference being that acronyms are abbreviations that are pronounced as words. Some on the list that qualify would be AMP, ASHI, CREIA, HVAC (maybe), InterNACHI, J-Box, NAHI, and OSHA. I have not heard any of the others used as acronyms.
    Thanks,
    Aaron
    Texas Inspector
  32. #32
    It's pretty clear that Brian has made it so you can hover your mouse cursor over the acronym/abbreviation to find out the meaning. Pretty helpful, particularly to the newer inspectors who don't know terms like AHJ. Just hover over the letters and you will see the definition.
  33. #33
    Washington State
    Here's a few
    WDO - Wood Destroying Organism
    WDI - Wood Destroying Insect
    SPI - Structural Pest Inspector
    PB - Polybutylene
    SIP - Structural Insulated Panel
    ICF - Insulated Concrete Forms
    DWV - Drain-Waste-Vent
    PWF - Permanent Wood Foundation
    FUBAR - Flubbed up beyond all recognition
