Results 1 to 32 of 32
Thread: Land Mines for Inspectors
11-14-2007, 06:55 AM #1
Similar Threads:- Without any guidelines for inspectors, how do you know your home ... - Nashua Telegra
- Critics say NH lags on regulating home inspectors - Foster's Daily Democrat
- Regulate builders, inspectors of houses - Nashua Telegraph (subscription)
- Regulate builders,inspectors of houses - Nashua Telegraph (subscription)
- Saving Money With Home Inspectors
11-14-2007, 07:25 AM #2
Re: Land Mines for Inspectors
Yikes! I hope you're ok.
I've never had anything remotely like that happen - knock on wood.
11-14-2007, 07:32 AM #3
Glad to hear you are OK. I gotta' wonder - any chance the tester faulted?
11-14-2007, 07:34 AM #4
thanks for the heads up--or should I say heads down.--Ill carry a fire extinguisher and say a pray before inspections.
11-14-2007, 07:53 AM #5
Robert,
Glad to hear your sorta ok.
Did you ask the homeowner for their homeowner insurance company provider name?
Was this some kind of new wiring? I've never heard of F******wiring yet? I'll ask the guys at the big orange box while I'm in there today if they can show me this new f****** wiring and explain its hazardous condition to them.
11-14-2007, 09:11 AM #6
Glad you are ok.
Any chance this house had aluminum wiring?
Here is a picture from yesterday's inspection. It is a kitchen outlet with aluminum wiring.
11-14-2007, 09:24 AM #7
Thanks guys. I'm fine.
No aluminum wiring.
THE TESTER IS NOT AT FAULT - THAT'S MY ANSWER AND I'M STICKING TO IT. The tester worked fine on all other outlets until I got to that one.
Lou, now imagine the entire wall burned and ceiling above it....
I'm not fretting over this in terms of liabilty. Could care less , actually. I'm living that's all that matters. Just got a headache.
Can't wait to find out what the root cause will be, though.
11-14-2007, 10:42 AM #8
Robert,
Did it feel like this?
11-14-2007, 10:59 AM #9
Robert
Something like that happened to me ONCE, had the multimeter set to read miliamps, I think. No fire, but did have fireworks.
11-14-2007, 11:21 AM #10
Yo, Robert-- what Rick H. stated above is a very good come back (regarding asking for their homeowners insurance carrier and policy#). I think the homeowner does have the responsibility/ liability of your safety, and in this case, hospital bill. That POS homeowner coming after you and speaking to you as she did, deserves to be knocked on her own arse by the same outlet.
rr
11-14-2007, 04:04 PM #11
In NC the "Offer To Purchase Contract" that was Revised 7/2007, paragraph 17 say that the Buyer and Buyer contractors are responsible for any damage done while on the property. A copy is attached.
Not sure how it is on other states but the agents I deal with are well aware of it!
11-14-2007, 04:30 PM #12
James,
I submit to you that Robert caused no damage to the property. All he did was find a defect. This is the same as if you "FIND" that the roof is bad.
Would you expect to have to replace the roof since *YOU* are the one that found the defective roof during the course of a normal inspection???
Of course not....
The homeowner, on the other hand, can certainly be held responsible (via their homeowners policy) any personal injury caused to a person invited onto your property-- and in alot of cases, even if they were not invited.
I tell ya, *any* realtor will have one hell of a time proving that this was a case of negligence or an error on the inspectors part. They just don't have a leg to stand on.
Rich
11-14-2007, 04:31 PM #13
James,
I opened your pdf and it was upside down.
That said there is a huge difference between causing damage and being injured on someones property. Repairman working on an appliance and the light fixture falls on his head.Did he damage the light fixture or was he doing what he was contracted to do and was injured by the light fixture?
11-14-2007, 04:47 PM #14
Billy...
You need to rotate it!
I did not say anyone was at fault. I just passed along some information.
11-14-2007, 04:56 PM #15
11-14-2007, 05:10 PM #16
But the buyer is on the hook for repairing any damage done by his inspector(s).
11-14-2007, 05:24 PM #17
I spoke with a member of the NC licensing board Friday about the HI being responsible for damages causing turing an inspection.
His response was, if you probe a piece of soft and rotten wood and cause a minor hole, the wood was already damaged, you did not cause any damage. No liability. If you pry off an entire piece of lap siding, you are responsible.
During a ConEd class the instructor told the story he experienced while he was an investigator for the licensing board following up on customer complaints.
HI found the windows sills were deteriorated and cracked. He took a screwdriver, jammed it in the crack and broke off the rotted sill on every window in the house. His explanation was now they would have to repair the damage. He claimed he did everyone a favor. In such a case, the HI would be liable.
The interperation is minor holes made while probing with a finger or screwdriver tip are acceptable. Removing pieces of the homeis not acceptable.
11-14-2007, 05:35 PM #18
There is no damage done by the Inspector. The damage was done by a defective outlet.
If he had turned on a faucet and water went every where the damage was caused by the defective device.
A normal expectation is to operate an item as intended. Open a door if the knob comes off in your hand defective. Turn on the heat and it explodes defective.Plug an electrical device into an outlet it catches on fire defective.Any damage caused was done due to defective items owned by the seller.
Fall off the Roof,Kill Poodle,Ladder Bust Sellers Window damage buyer is responsible for.
11-14-2007, 05:50 PM #19
11-14-2007, 06:13 PM #20
While I agree that Robert "did not cause the fire" and thus the buyer has nothing to hold the seller harmless from ...
... I also submit that the final word will come from what the forensic investigator determines was wrong and the judge's take on it.
If the action of plugging in a tester 'caused' the receptacle outlet to fail, which 'caused' the resulting fire, then the action of plugging in that same tester into any and every receptacle outlet would 'cause' the same results ... but it did not.
Likewise, if plugging something into that receptacle outlet 'was not the cause' of the resulting fire, then the receptacle outlet had to have been previously 'defective or damaged' in some way. That's where the forensic investigator removes the receptacle and determines what was what when.
11-14-2007, 06:28 PM #21
I guess my point was is that it could be a problem that I hope i never experience. I have had some agents say that in the future their company may require a contract between them (the agent) and the inspector to cover this problem. The "what insurance do you carry" issue has also come up more often recently. With the right seller who is aware what Paragraph 17 says this could be a problem for a NC inspector.
11-14-2007, 06:35 PM #22
That's been in the majority of the real estate contracts used in Florida for over 15 years that I know of, and I think it has been in there even longer, and the example given about the decayed wood and probing and breaking out window sills is basically how they address it as being 'already damaged' or 'the inspector damaged it'. Unless the inspector really rips things apart, it is typically considered 'already damaged' (it was "already" "damaged" by the wood decay/termites/whatever).
11-14-2007, 06:45 PM #23
11-14-2007, 07:16 PM #24
I have $2 mil ...... Farm Bureau.....
Don't want to use it though..
11-14-2007, 07:58 PM #25
11-14-2007, 09:50 PM #26
11-14-2007, 10:22 PM #27
11-15-2007, 06:18 AM #28
11-15-2007, 09:14 AM #29
Most builders will now require the inspector to submit to having atleast a 1M GL policy. Some require the 2M (just not many).
But what the heck, not very expensive.
rr
11-15-2007, 09:18 AM #30
Food for thought:
$1M E&O = ~$2100/annual (State Farm)
$2M GL (w/$4M aggregate) = $350/annual (Hartford)
I'm not complaining at all. I'm pleased with my rates/coverage ... just like any in$urance ... hate to pay for the "future possibility of things that you never want to happen".
11-15-2007, 11:26 AM #31
My GL went down this year. For 1M I pay around $200 from Shelter Insurance. The rate depends on your past history and the area you live in. I have had Shelter for around 12 years with no claims!
11-17-2007, 09:52 AM #32
Fire extinguishers should be mandatory equipment for any inspector who has significant volume. Though I've never had to use mine, I have had close calls.
