Results 1 to 11 of 11
Thread: Problem with answering posts
12-19-2016, 02:14 PM #1
I am new to this board. I don't understand why my space bar does not work when I am typing a response to posts. Everythingcomesoutalltogetherlikethis.
What am I doing wrong.
MERRY CHRISTMAS ONE AND ALL
Cheers
12-19-2016, 02:32 PM #2
Re: Problem with answering posts
It appears to be browser specific. Jerry pointed that out about Google Chrome.
If you open a post directly from an email notifications and log in the same thing happens to me.
Myself, outlook tracing.
I now go to InspectionNews, open what's New?, login, and everything works.
No formatting issues from Outlook email server.
Doug, hope that helps!
Cheers mate.
12-19-2016, 02:39 PM #3
12-19-2016, 03:52 PM #4
Doug,
The solution is to type the first word, enter a line return, then arrow key backwards to get to the end of the first line (or use you mouse and click there) ... then it works as it should.
12-19-2016, 04:43 PM #5
12-19-2016, 04:47 PM #6
12-20-2016, 09:53 AM #7
Let me know more specifics as to the system and browsers (and if they are both up to date) that are having issues. I have never run into this issue but if I can find a solution I'll do what I can.
Sincerely,
Brian Hannigan
Twitter: @InspectionNews
12-20-2016, 11:52 AM #8
Hi Brian:
I use win 7 and Chrome which I think is up to date. Not sure how to tell if it is or not.
I took Robert's advise and switched to Firefox when I want to reply to a post here and it works fine.
I did not have the problem when posting a new thread when I use Chrome.
Cheers
12-20-2016, 12:09 PM #9
Brian,
I use Windows 10 and Chrome, both are up to date.
Every now and then a reply will work without that issue, but not often ... that may be because I enter a name as I did here, hit the enter and ... the problem is solved at that point when I didn't even think about it?
12-20-2016, 01:36 PM #10
Win 10 64 bit, Chrome latest update.
The anomaly appears to be outlook & format related or/and/maybe sync related issue between devices.
I use a computer, Win 10 64 bit, Chrome latest update on both my PC and Window Surface Pro 4.
Wind card, android synced emails.
Anomaly: Log in directly from an email link the space bar does not move your cursor forward to allow spacing yet you can drop down lines.
Experiences: Logging in from outlook link.
a. I actually typed full sentences using the spacebar to separate the words at the end.
Worked 99% of the time.
b. I tried successfully to drop the cursor 2 lines down before typing although that was not successful all the time.
The anomaly never appears when I log on from Chrome.
Hope that helps.
PS: You have to smile reading Gunners post. Ha ha ha
12-21-2016, 10:43 AM #11
Thanks for the info and if anyone else wants to add to it please do.
I have Win 10 and use Chrome and never run into the issue on a thread although I did see what you were talking about when I replied to a private message.
Thanks for the info.
Sincerely,
Brian Hannigan
