    daniel nantell's Avatar
    daniel nantell Guest
    Default flexible copper gas line to water heater.
    I saw a flexible copper gas line to water heater, no drip leg, no gas shut off for the appliance., I called the issue out and recommended having further evulations of the water heater by a plumber. The fha inspector came throught and did not take any exception to the flexible copper tubing. I thought all gas appliances had to have a gas shut off, drip leg and gas line should be black steel piping .
    Default Re: flexible copper gas line to water heater.
    Quote Originally Posted by daniel nantell View Post
    fha inspector
    That's an oxymoron for sure.
    Healdsburg, CA
    Good-grief Mr. Peck, I find your post bitter-sweet and I think you're being a bad-sport about FHA-Inspectors.
    david ju's Avatar
    david ju Guest
    DRIP LEGS REQUIRED AND MUST BE DOWNSTREAM OF THE SHUTOFF VALVE.
    Only 3 replies yet has 1900 views. So I click, then see that the OP is 3 years old. It was never answered, untill now.
    May 2009
    Washington State
    nevermind : )
