Results 1 to 3 of 3
08-11-2008, 01:53 PM #1
checking air temp. for a/c operations
When checking the air temp. on a a/c , would you get a more accurate temp. using the old bulb type themoter, or using these new type laser ones , I would think the old one measuring air temp. would be the most accurate, any feedback from the a/c men.
08-11-2008, 01:57 PM #2
Re: checking air temp. for a/c operations
Try this recent thread:
http://www.inspectionnews.net/home_i...ferential.html
08-11-2008, 06:23 PM #3
Use a probe type meter, not the IR. The IR will give you wrong readings. Since it is going to measure the temp of the sheetmetal or whatever instead of the air.
