Old 09-17-2007, 09:11 AM
Lynn Petrie Lynn Petrie is offline
Electrical panel bonded ?
Could someone explain to me in certain terms when someone asks is the electrical panel bonded ? What do you look for ? Any pictures would help
Home inspection
Old 09-17-2007, 09:28 AM
John Arnold John Arnold is online now
Re: Electrical panel bonded ?
The panel enclosure, the metal box itself, needs to be bonded to ground so that it cannot become energized by a loose wire, for instance, and become a shock hazard for the next person who touches it. You are looking for a green screw in the grounding bar that screws into the back of the enclosure, or a copper connector from the ground bar that screws into the enclosure, and I'm probably forgetting some other things. I'll look for photos.
Old 09-17-2007, 09:36 AM
I said copper connector, but it could be aluminum like this one. Obviously, this isn't connected to the bar yet.
Old 09-17-2007, 09:38 AM
Also, try searching the board for "bond screw" , or "panel bond", etc., (probably without the quotes) and you'll find more info and photos.
Similar Threads
electrical question Elliott Taylor Electrical Systems: Home Inspection and Commercial Inspection 8 08-04-2007 08:34 AM
exterior electrical cable. Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 6 07-06-2007 05:14 PM
Electrical help needed william siegel Electrical Systems: Home Inspection and Commercial Inspection 7 06-22-2007 05:30 PM
Electrical tape Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 7 06-19-2007 06:41 AM
electrical support John Arnold Electrical Systems: Home Inspection and Commercial Inspection 3 05-25-2007 10:13 PM
vB.Sponsors
Ad Management by RedTyger
