Old 02-12-2008, 06:38 PM
John Jacobs John Jacobs is offline
Help me with my garage foundation cost est??
Hello All,
Does anyone have any clue what the going rate is for block work? I am building a small garage 30 x40 and estimating. Considered ICFs but may be too expensive. I need to go 2' below grade to top of footing. Then 1' above grade. Frame up from there. Pad is poured concrete. Ideas?
Many thanks,
Jake
Old 02-12-2008, 06:39 PM
Re: Help me with my garage foundation cost est??
On Eastern Shore of Maryland
Old 02-14-2008, 11:18 PM
Trent Tarter Trent Tarter is offline
John I would just build a post frame building (pole building). This is about the lowest cost durable building you can build and it won't need a foundation. Just footings at each post. You can even build them now without sinking the posts into the ground. They can attach the posts to the slab.
Old 02-15-2008, 06:57 AM
Scott Patterson's Avatar
Quote:
Originally Posted by John Jacobs View Post
Hello All,
Many thanks,
Jake
What does concrete cost per yard in your area?
Do you want electrical service in it?
What type of siding?
What type of doors, windows?
What type of roof?
Scott Patterson
Old 02-15-2008, 12:35 PM
Brian E Kelly Brian E Kelly is offline
John your question is open ended as there are way to may options avaliable. I was once asked what is a ball park price? I thought about it and answered, about 10-70 million depending what team you are buying.
Well thats my 2 cents.
Brian Kelly
Kelly Home Inspections
Similar Threads
Water stained garage foundation Jerome W. Young Sub-Structure: Home Inspection and Commercial Inspection 18 12-17-2007 07:49 PM
Start up Cost Neavrae Gibson Business Operations: Home Inspectors & Commercial Inspectors 1 09-17-2007 10:39 PM
Cost of a chimney metal cap John Stephenson Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 9 05-18-2007 05:08 PM
Cost of War Rick Hurst General Chit Chat: Home Inspectors & Commercial Inspectors 7 05-02-2007 12:27 AM
Cost of Business Button Tim Moreira H E L P ! 8 04-03-2007 10:38 PM
vB.Sponsors
Ad Management by RedTyger
