Old 07-10-2008, 09:08 PM
Tim Miller Tim Miller is offline
AC Coil Installation
Can an AC coil be installed backwards on the unit. the unit is aged by some 12 -15 years and is a seperate unit connected to a gas furnace. I amsorry that I dont have a picture to illustrate the type of coil.
thanks for any input.
Tim
Old 07-11-2008, 09:34 AM
Sal Castro Sal Castro is offline
Re: AC Coil Installation
The inlet / outlet orientation should not matter on most installations (horizontal) to the air flow. Of course flipping it upside down would create condensate drain issues on vertical A-coils or any coil assembly with integral drain pan.
Old 07-11-2008, 09:39 AM
On a 12 to 15 year old unit, if you are having air flow problems, I would be willing to bet the coil needs a good cleaning, especially if filter maintenance has been negligent.
I have seen drastic improvements in capacity after a good cleaning. (Surface cleaning doesn't quite do it)
Old 07-11-2008, 10:13 AM
By the time you do a "good cleaning", which requires removal of the coil.
I always advised my clients to "put an extra $100 or so in and just have a new coil installed, by the time you pay to have the old coil cleaned, you still have an old coil which is not-as-clean-as-new, yet you have almost paid that much just to clean the old coil ... replace the coil with a new one".
Similar Threads
HVAC New Installation Ken Larson Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 6 09-26-2008 02:51 PM
Furnace installation Allen Lott Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 3 05-07-2008 09:03 PM
drywall installation Jerome W. Young Building Interior: Home Inspection and Commercial Inspection 7 02-20-2008 07:13 PM
New roof installation william siegel Roofing System: Home Inspection and Commercial Inspection 23 01-29-2008 08:32 PM
Dryer Vent Next To Condensing Coil imported_John Smith Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 12 04-29-2007 03:52 PM
vB.Sponsors
Ad Management by RedTyger
