steel I beam was prevented to turn on the back side as it was tight against foundation wall, but the visible side did not have anything to prevent it from sliding or turning. It this acceptable practice. thanks
Really need a picture Daniel in order to give any feedback. You might want to review similar posts regarding connections to get an idea if what you are seeing is proper.
Daniel
From what you describe it appears one end of steel I beam is braced well against overturn so it’s very doubtful the other, so called open end, could rotate off its support system. As long as it is well supported and securely attached and there is no visual evidence of any problems I wouldn't bother making recommendations for review by a SE.
All Rights Reserved. Hann Tech Marketing Link / InspectionNews.com / InspectionNews.net - No part of InspectionNews.net may be reproduced in any way, or by any means, without the prior written permission of InspectionNews.net. Use of any index or listing Software for the purpose of constructing a mailing list, creating promotional materials or producing a printed or electronic catalog of any kind is expressly forbidden without the prior written permission of InspectionNews.net - All text, graphics and design on InspectionNews.net is copyright by Hann Tech Marketing Links. Ad Management by RedTyger
