Old 07-13-2008, 09:49 PM
daniel nantell daniel nantell is offline
steel I beam
steel I beam was prevented to turn on the back side as it was tight against foundation wall, but the visible side did not have anything to prevent it from sliding or turning. It this acceptable practice. thanks
dmn
Old 07-14-2008, 04:37 PM
Mitchell Toelle Mitchell Toelle is offline
Re: steel I beam
Really need a picture Daniel in order to give any feedback. You might want to review similar posts regarding connections to get an idea if what you are seeing is proper.
MPT
Old 07-14-2008, 04:51 PM
Jerry McCarthy's Avatar
Re: steel I beam
Daniel
From what you describe it appears one end of steel I beam is braced well against overturn so it’s very doubtful the other, so called open end, could rotate off its support system. As long as it is well supported and securely attached and there is no visual evidence of any problems I wouldn't bother making recommendations for review by a SE.
Construction Consultant
Similar Threads
Aluminum vs. Galvanized steel Tom Kartheiser Introductions By New Members 3 03-04-2008 05:50 PM
Steel Framing connections dan orourke Attic Areas: Home Inspection and Commercial Inspection 2 09-13-2007 09:24 AM
Foundation Steel? dan orourke Structural Components: Home Inspection and Commercial Inspection 8 09-11-2007 07:08 PM
Cut End on Steel I Beam Nick Ostrowski Structural Components: Home Inspection and Commercial Inspection 3 05-22-2007 12:57 PM
Steel framing Phillip Stojanik Structural Components: Home Inspection and Commercial Inspection 6 04-14-2007 02:21 PM
vB.Sponsors
Ad Management by RedTyger
