Old 08-11-2008, 02:53 PM
daniel nantell daniel nantell is offline
checking air temp. for a/c operations
When checking the air temp. on a a/c , would you get a more accurate temp. using the old bulb type themoter, or using these new type laser ones , I would think the old one measuring air temp. would be the most accurate, any feedback from the a/c men.
dmn
Old 08-11-2008, 02:57 PM
John Arnold John Arnold is offline
Re: checking air temp. for a/c operations
Try this recent thread:
Measuring temp differential
Old 08-11-2008, 07:23 PM
Use a probe type meter, not the IR. The IR will give you wrong readings. Since it is going to measure the temp of the sheetmetal or whatever instead of the air.
Markus Keller
Old 08-11-2008, 10:00 PM
fritzkelly fritzkelly is online now
After 10 minutes or so, the sheet metal register should be the same (or nearly) as the air from the register. The IR will work just fine. I see AC guys using them all the time.
Home inspection
Similar Threads
Measuring temp differential Peter Wigle Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 58 08-18-2008 06:22 PM
Hot temp on ACFI's Gregg Austensen Electrical Systems: Home Inspection and Commercial Inspection 11 05-27-2008 11:23 AM
Heat Pump temp defferntial Anthony Alderman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 7 02-26-2008 09:34 AM
Attic temp during our heat wave ren ramsey InspectionBlues: Home Inspectors & Commercial Inspectors 15 08-15-2007 07:47 AM
Temp dif split Kevin Fuqua Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 15 05-06-2007 05:44 PM
vB.Sponsors
Ad Management by RedTyger
