Old 09-04-2008, 02:11 PM
John Dirks Jr's Avatar
John Dirks Jr John Dirks Jr is offline
split level
I'm just curious about this but when did the split level home design first show up on the scene? I'm doing one tomorrow and it's said to be built in 1965. I didn't think they were around that early.
John Dirks Jr
Arundel Home Inspection LLC
http://www.arundelhomeinspection.com
Old 09-04-2008, 02:36 PM
Rick Hurst's Avatar
Rick Hurst Rick Hurst is online now
Re: split level
Split level homes most started back in the 1950's and 60's. Some are even older.
Most common problems I've seen is:
Stair problems
Improper grading
Uneven heating / cooling
Outdated equipment
Electrical Service equipment problems
Just to name a few.
Old 09-04-2008, 02:38 PM
Brandon Whitmore Brandon Whitmore is offline
Re: split level
50's according to this article
An American Vernacular: The What, How & Why of Bi-level and Split-level homes
Old 09-04-2008, 03:28 PM
Jack Feldmann's Avatar
Jack Feldmann Jack Feldmann is offline
Re: split level
We have tons of split foyer homes that were built in the 70's and 80's. Odd design.
Old 09-04-2008, 04:31 PM
Ted Menelly Ted Menelly is online now
Re: split level
Quote:
Split foyer as in raised ranch?
By level and tri level have been around a long time. Those along with raised ranches and bilevels or side to side split level and trilevels were very popular in the 60's and earlier 70's in Mass.
Ted Menelly
"Castle"
Home Inspection Services
  #6 (permalink)
Old 09-05-2008, 08:36 AM
Re: split level
Thanks for the info. I didn't realize they were around that early
John Dirks Jr
  #7 (permalink)
Old 09-07-2008, 12:25 PM
Re: split level
Split foyer:
You walk in the front door and there is a landing, maybe 5'x6' with a short stair going up on the right, and a short stair going down on the left.
So it's really a 2 story house (bottom level is usually a walk out basement) and the garage is a part of the bottom level.
Downstairs is usually a 2 car garage, laundry room/1/2 bath, and then there is either one big room (sometimes a fireplace), or a bedroom and a family room/den. Upstairs is the normal 3/2.5, kitchen, dining room, living room.
Here's a couple photos of one........
  #8 (permalink)
Old 09-10-2008, 05:19 PM
Mike Schulz's Avatar
Mike Schulz Mike Schulz is offline
Re: split level
Split levels I see would be you walk into the front door with stairs going up and down. The section of the upper is on a dirt crawl space and of course the lower is slab. You go through a scuttle hole on the lower section to get under the upper floor crawl space. Sort of like a half basement.
Mike Schulz License 393
Affordable Home Inspections
www.houseinspections.com
  #9 (permalink)
Old 09-10-2008, 07:19 PM
Re: split level
Split foyer:
That is a raised ranch Jack. They started in the mid to late 60'o maybe early 70's
Ted Menelly
"Castle"
  #10 (permalink)
Old 09-11-2008, 07:45 AM
Brandon Chew Brandon Chew is offline
Re: split level
Quote:
Around here, we also call those a raised ranch. Could be a Northeast thing ...
  #11 (permalink)
Old 09-12-2008, 08:59 AM
Sal Castro Sal Castro is offline
Re: split level
Here on Long Island they call them "High Ranches".
I find many with foundation waterproofing seepage causing problems at the bottom of the finished wall of the lower level where it is below grade.
  #12 (permalink)
Old 09-12-2008, 12:29 PM
Darren Miller's Avatar
Darren Miller Darren Miller is offline
Re: split level
In New Jersey we call them Bi-levels
Darren
Succasunna, NJ
www.aboutthehouseinspections.com
  #13 (permalink)
Old 09-12-2008, 09:17 PM
Joe Klampfer's Avatar
Joe Klampfer Joe Klampfer is offline
Re: split level
Quote:
You're right - That one is a bi-level... a split-level looks more like...
  #14 (permalink)
Old 09-12-2008, 09:57 PM
Re: split level
Quote:
Now that picture is a tri-level or is it a qud level???
Ted Menelly
"Castle"
Similar Threads
split beam? Ron Bishop Structural Components: Home Inspection and Commercial Inspection 9 11-10-2008 05:35 PM
Stranded conductor split under two terminal screws? Michael Vasquez Electrical Systems: Home Inspection and Commercial Inspection 3 03-27-2008 03:41 PM
Split bus ? Rick Cantrell Electrical Systems: Home Inspection and Commercial Inspection 2 10-20-2007 05:23 PM
Temp dif split Kevin Fuqua Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 15 05-06-2007 05:44 PM
Split Busbar Jim Makara Electrical Systems: Home Inspection and Commercial Inspection 1 04-23-2007 02:59 PM
vB.Sponsors
Ad Management by RedTyger
