Results 1 to 16 of 16
Thread: What is this
03-07-2010, 10:28 AM #1
What is this
Looked at a Bosch dishwasher yesterday and there was no traditional air gap. Found the manual in a drawer and this pictured item wasn't part of the included parts with dishwasher. Is this some kind if air gap or anti back flow device that anyone can identify?
Thank for you help in advance.
03-07-2010, 11:50 AM #2
Re: What is this
www.inspectaz.com
03-07-2010, 11:56 AM #3
03-07-2010, 12:01 PM #4
Re: What is this
Not a clue. Did you see the back side?
03-07-2010, 12:05 PM #5
Re: What is this
Appears to be a one way valve.
03-07-2010, 03:14 PM #6
03-07-2010, 05:31 PM #7
Re: What is this
It's an in-line check valve.
03-07-2010, 05:34 PM #8
03-08-2010, 07:18 AM #9
Re: What is this
The manual says air gap....!!
03-08-2010, 07:01 PM #10
Re: What is this
Isn't the air gap created inside of the garbage disposal ?
03-08-2010, 07:04 PM #11
Re: What is this
"Isn't the air gap created inside of the garbage disposal ?"
Not if the disposal is backed up.
03-08-2010, 07:14 PM #12
03-08-2010, 07:16 PM #13
Re: What is this
Not to down play the requirement to report the absence of an air-gap, but has anyone ever tried blowing into the drain line of a dishwasher? I have and believe you would blow both eyeballs out of there sockets before forcing anything back into the dishwasher. I've tried several different brands and the ones I have tried all have check valves installed.
(I still report the absence of an air-gap or high loop)
03-08-2010, 07:17 PM #14
Re: What is this
Rick, what would qualify as an air gap? I'm not sure what the manufacturer is asking for.
I just assumed that so long as the water from the dishwasher entered the drain above the trap, the install was alright.
03-08-2010, 07:21 PM #15
Re: What is this
Thank you Billy.
03-08-2010, 07:40 PM #16
Re: What is this
"Not to down play the requirement to report the absence of an air-gap, but has anyone ever tried blowing into the drain line of a dishwasher? "
Most DW have a BF device built in.
That is why you cant blow in to the drain line.
DW with instructions that say to install air gap, most likely do not have BF device.
Air gap is perfered over BF device, everytime.
There are 2 air gaps or BF device on a DW.
1 for the supply and 1 for the drain
Supply is most often a built in air gap
Drain is most often built in BF device.
