Thread: Heat Pumps
09-29-2010, 07:55 AM #1
Heat Pumps
Why is it not a good idea to inspect a heat pump in the heat mode during hot weather and in the cool mode during cold weather?
09-29-2010, 09:37 AM #2
Re: Heat Pumps
ive never had an issue of doing that, its only the reversing valve you are testing, test as normal, below 40 deg. in the heat mode is not very effetive
09-29-2010, 10:39 AM #3
Re: Heat Pumps
I've always heard that running a heat pump in the cool mode during cold weather could damage the compressor because of the lubricant in the compressor, which I suppose is not warm and not very lubricating. However, I also understand that it is not good to run a heat pump in the heat mode during warm weather; I don't understand why?
09-29-2010, 10:50 AM #4
Re: Heat Pumps
Since the heat pump picks up heat from the outside air, on a hot day the refrigerant pressures can get too high and cause damage. Most likely it won't be it could. It is okay for a HVAC tech to run the system because he can monitor the pressures with his gauges.
09-29-2010, 11:15 AM #5
09-29-2010, 07:31 PM #6
Re: Heat Pumps
Below 40 deg? You must be talking about the old heat pumps.
The new ones that use R410 work really good down to about 26 degrees.
They still work below that but need an occasional boost from the electric strips.
I have tested both of mine with the electric strips programmed to stay off to see how they did in really cold weather. This was done on a well insulated house with high end windows and R38 in the attic.
www.BAKingHomeInspections.com
09-29-2010, 08:18 PM #7
Re: Heat Pumps
