Results 1 to 2 of 2
Thread: ProfessionalM
07-02-2012, 10:29 AM #1
07-02-2012, 04:52 PM #2
Re: ProfessionalM
Must have's:
1) The ICC Mechanical code of the right edition for the test - are they still using the 2009 or have they switched to the 2012 yet?
2) The ICC Practice Tests.
3) Repeat 2) above until you get every answer right and can complete it within the time allotted. ICC has multiple versions and questions for their practice tests, you will get repeat questions after going through the practice test a few times, but what you are getting is the format of their questions and familiarity with the code book.
If you were not familiar with the code book before then, you will be afterward.
