Results 1 to 2 of 2
    Dean Aliberti's Avatar
    Dean Aliberti Guest
    Default Gas water heater connected to a oil fired boiler vent pipe
    Is there a code violation if a gas fired water heater vent pipe connects into a oil fired boiler vent pipe which then connect into the sealed chimney vent?
    Inspection Referral SOC
    Nov 2009
    St Paul, MN
    Default Re: Gas water heater connected to a oil fired boiler vent pipe
    IRC 2427.5.6.2 allows it. If the gas utilization equipment is automatically controlled it's required to have a safety shutoff device. Your local codes may restrict it though.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
