Results 1 to 33 of 33
06-07-2013, 01:39 PM #1
I can't get rid of this box on all pages
The attached photo shows a box that pops up in the same place on all pages. Blocks out the view and function. The only way to get rid of it is to hit my browser back arrow.
Again, this is on ALL pages of this forum and shows up ALL the time. Very frustrating.
Am I the only one or is this a glitch in the software?
06-07-2013, 02:04 PM #2
Re: I can't get rid of this box on all pages
I have the same "box" on my PC but not on my iPad..... I thought it was somthing with my PC...
06-07-2013, 02:07 PM #3
............I have it also......Greg
06-07-2013, 02:41 PM #4
I run Chrome and have not seen it.
06-07-2013, 03:11 PM #5
For those that see that what operating system and browser are you running?
I have never seen it and I test on many different platforms.
Can you tell what page/link it is that can't be found?
Sincerely,
Brian Hannigan
Twitter: @InspectionNews
06-07-2013, 05:24 PM #6
Brian,
it is on "every" page. All of them.
I have windows 7, with Explorer 9.
This attached photo is the Page I am on now.
06-07-2013, 06:19 PM #7
www.inspectaz.com
06-07-2013, 08:02 PM #8
Vista, IE
Every page, every time for everything for a couple of weeks. Been meaning to complain but ....
06-07-2013, 08:42 PM #9
That's funny, was going to write the same thing.
XP
Explorer 8
06-08-2013, 05:08 AM #10
I have it also
06-08-2013, 05:22 AM #11
On Mozilla Firefox, I don't have it, but when I run Explorer it's there. My computer has XP.
06-08-2013, 08:23 AM #12
Interesting, same for myself.
Using XP Pro and Firefox, no box and no problems.
Using XP Pro and MS Internet Explorer and get the box.
Happens using the pass through page using Inspectionnews.COM to get to the Inspectionnews.NET
Also occurs using the Inspectionnews.NET directly.
Using AOL as home page with Explorer.
Change to open "Internet Explorer without add-ons", still get box.
Might be the result of one of the settings for Internet Explorer. TOOLS - OPTIONS - ADVANCED
Will try to play later to see if I can find anything under that basket to help.
06-08-2013, 07:08 PM #13
How many of you are running the most up-to-date Java?
06-09-2013, 06:02 AM #14
I don't have it on mine, Windows 7 or my other one with Windows XP.
Google Chrome on both.
Not on my Samsung Note 2 either.
06-09-2013, 06:52 AM #15
06-09-2013, 09:07 AM #16
Windows XP with IE8 - that annoying box shows up on every page.
- - - Updated - - -
06-09-2013, 04:53 PM #17
Down with Explorer
Up with Firefox
Long live alternatives...
06-09-2013, 09:23 PM #18
If you are having the issue try holding down the Ctrl key and hit F5. This should refresh the page from the server, not form your cache.
It looks like a component to a page was not available at one time and the IE has cached it.
See if the Ctrl + F5 will fix it and let me know.
Thank you.
Sincerely,
Brian Hannigan
06-10-2013, 02:26 AM #19
06-10-2013, 04:14 AM #20
06-10-2013, 09:27 AM #21
Delete your browser history,
Click the Start button on the Taskbar,
Click on Control panel,
Click on Internet options/ General section/ Delete button
Check All of the boxes and Uncheck the very top box,
Click on Delete.
Reset ie9 or ie10 manually,
Click on Internet options,
Go to the Advanced section,
Click on Reset button on the bottom,
Check the box to Delete personal settings,
Use the recommended setup and install options.
06-10-2013, 01:25 PM #22
Windows 7 Firefox - no issues
Windows 7 IE 7 through 10 - problems like the others
Windows 7 Chrome- no issues
06-10-2013, 02:09 PM #23
DO NOT DO THIS !!
I REPEAT ---- DO NOT DO THIS.
It does not fix the problem. It erases everything you ever had for favorites, passwords, webpages. etc. It's like starting all over.
It was irrisponsible for Jim Roberts to suggest this.
AND it does not fix the F-*&ing problem.
I would only do what Brian suggests. If you do anything else -- it is on your own.
06-10-2013, 03:52 PM #24
06-10-2013, 05:54 PM #25
no fix here either-window 7--tosiba laptop--HELP CVF
06-11-2013, 05:05 AM #26
Didn't make a difference.
06-11-2013, 09:24 AM #27
Latest Java from Starbucks, upgraded with foam.
06-11-2013, 09:43 AM #28
Should be fixed now.
Better?
Sincerely,
Brian Hannigan
06-11-2013, 10:12 AM #29
Kowabunga.... Tested it out......Believe you have it corrected. Good work.
06-11-2013, 12:59 PM #30
Fixed.
06-12-2013, 05:01 AM #31
........fixed. Thanks, Greg
06-12-2013, 08:09 AM #32
Ok. THe box is gone but....
There is no next page or similar button to see more posts. As long as the topics are on the first page, good to go. If on the second page, oh well.
06-12-2013, 10:24 AM #33
Sincerely,
Brian Hannigan
