Results 1 to 30 of 30
    Jun 2008
    St. Thomas Ontario, Canada
    Default WEB SITE REQUIRES MAINTENANCE!
    Bryce Jeffrey
    Jeffrey Home Inspection
    St. Thomas, Ontario, Canada
    Aug 2011
    Default Re: WEB SITE REQUIRES MAINTENANCE!
    I know Brian is aware of this problem. I just had a duplication and the site freeze up. It is annoying.
    Jun 2008
    Thank You, glad it's general and just not me!
    - - - Updated - - -
    - - - Updated - - -
    - - - Updated - - -
    - - - Updated - - -
    - - - Updated - - -
    Bryce Jeffrey
    When it doesn't post the first time, wait for the error message, hit the back arrow and let that reload, hit the back arrow one more time and let that reload, ... then hit the refresh page - your post will show at the top.
    The multiple postings are from hitting Submit multiple times.
    Orlando, FL
    Quote Originally Posted by Bryce Jeffrey View Post
    Extremely difficult to post. At least on my end. Duplication, delay in typing
    This site has had serious usability issues for a lot longer than the recent double, triple, multiple posting anomaly...
    Dom.
    Capistrano Beach, CA
    Hi All,
    Thank you for hanging in there. I am having some server work done tomorrow and with a little luck that will cure the problems. If not I will have some other work done until we get this sorted out.
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    The first update took place last night.
    Another update will take place late tonight.
    Keep me posted if issues continue.
    Sent from my SCH-I605 using InspectionNews mobile app
    Sincerely,
    Brian Hannigan
    Outside links coming into specific pages on InspectionNews will be broken for a little while.
    We had to remove an SEO component that rewote all the URLs. We now need to duplicate that rewrite. Unfortunately not as easy as it should be but working on it.
    Sincerely,
    Brian Hannigan
    Thumbs up Re: WEB SITE REQUIRES MAINTENANCE!
    I'm holding my breath but I haven't seen a database error since the update this afternoon.
    Fingers crossed we beat the beast.
    Let me know if you have any issues.
    Sincerely,
    Brian Hannigan
    Quote Originally Posted by Brian Hannigan View Post
    Outside likes have been fixed.
    Sincerely,
    Brian Hannigan
    Thanks Brian for your diligence!
    What I noticed that started happening a day or two ago was that I would initially get the full board, read a post, then only get the part of the board that post was in.
    I could click on the Forums tab and get the full board back.
    I'm not completely sure what you mean but keep me posted if that continues and at that point help me to understand a little better.
    As far as I can tell there are not database errors when posting now.
    Sincerely,
    Brian Hannigan
    Things are working fine from my end and have been since the upgrades.
    Database error
    The DragonByte SEO database has encountered a problem.
    Database error
    Crap! Rick, you broke it!
    OK, still work to be done on my end but it appears to be much better. That is the only error (I get an email when an error occurs) that I have seen today.
    I have more tricks up my sleeve and will get to them soon.
    Thanks for the feedback.
    Sincerely,
    Brian Hannigan
    Some more tweaks made today.
    Are we making progress? Less (or hopefully no) errors?
    Sincerely,
    Brian Hannigan
    Less errors, yes, seems much better now.
    My problem may have been a memory issue (mine) in that I recall that as I worked my way back up from reading a post and a thread, both technical and non-technical sections would appear automatically together - now I have to do one additional click on 'Forums" to get both.
    May be just me remembering what I thought I did and now have to do is actually what I had to do before but didn't know I was doing it ... if that makes any sense.
    The thing I have noticed recently is that when I click back up from a thread, such as this thread and click 'Help', it used to show that I read it (not bold), now it shows it as unread (bold) unless I go back to the thread and then back up - then it shows as read.
    Multiple email notifications again from Crown Vent discussion.
    The 'can you find the conflict' thread always loads with the 4th page loading when the others load with the first page loading. That also leads to not showing up as 'read' (showing up as 'unread').
    Not sure if there may be other forums/threads which do the same.
    Looks like others are also experiencing long posting times and click the submit button several times to get their reply posted, which results in multiple duplicate posts and updates.
    As a fellow inspector, you should know...."It failed during testing"
    Aug 2011
    Check out the tankless thread....there may still be a problem.
    Apr 2007
    WESTMINSTER CO
    typing is still an issue here--and I have to go bacdk and retype--frustrating--see work back here
    cf
    Apr 2007
    WESTMINSTER CO
    brain
    iam still having trouble typin words on this bpage as youcan see byth repl--whatis the problem-am I th onl one
    charle
    top line typed with normal typing this one with pause between each letter
    brain
    charle
    Charlie, I have not heard about this issue from anyone else and I can hold down on a single key and the letters zip across the screen...
    NNNNNNNNNNNNNNNNNNNNNNNNNN
    ooooooooooooooooooooooooooooo
    PPPPPPPPPPPPPPPPPPPPPPPPPPPP
    rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
    bbbbbbbbbbbbbbbbbbbbbbbbbbbbb
    llllllllllllllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllll
    eeeeeeeeeeeeeeeeeeeeeeeeeeeee
    mmmmmmmmmmmmmmmmmmmmm
    What operating system and browser do you use and have your tied a different browser?
    Sincerely,
    Brian Hannigan
    Apr 2007
    WESTMINSTER CO
    windows 9.7 and aol--this only started after your web work few months ago---will try explorer
    thanks
    Charlie
    thanks
    Charlie
    My first guess would be AOL. I would try Chrome or Firefox. Explorer is a dog as well.
    Sincerely,
    Brian Hannigan
    One thing I've noticed is that the post does not change from bold-for-unread to not-bold-for-read after I make a post and go back up the forum thread chain, but ... when I read a post the change takes place.
    That is with my phone (Samsung Note II Android), my notebook (Windows 7 with Chrome), my old desktop (Windows XP with Chrome), or my brand new desktop today (Windows 8.1 with Chrome).
    Any one else having that happen too?
    - - - Updated - - -
    And that dang double post too because I thought it was not working ... it was, just v-e-r-y s-l-o-w-l-y as it turns out.
    Multiple emails indicating a single post.
    All else seems fine for me.
    Jun 2008
    I still encounter difficulties while attempting to post. This time I received an error message. Logged out and found my post was entered twice.
    Bryce Jeffrey
