Old 12-11-2008, 05:09 PM
tim reaves tim reaves is offline
foundation this can be correct
In the photo you can see the foundation thin the bottom plate and then a piece of plywood shimming up the outside band Joist. could this type of shimming have been approved.
IC Home Inspection Report Writing
Old 12-11-2008, 05:14 PM
Richard Pultar Richard Pultar is offline
Re: foundation this can be correct
ask who ever approved it
Old 12-11-2008, 06:19 PM
Jerry Peck's Avatar
Tim,
No, plus, with that anchor bolt shown holding that sill down, I suspect there should be some uplift straps too.
It does not good to hold the sill plate down and not strap the stuff above it to the sill plate.
Old 12-12-2008, 05:06 AM
A.D. Miller's Avatar
A.D. Miller A.D. Miller is offline
Quote:
No.
Plus:
(1) Softwood shims on th top of the pier are wrong.
(2) Girder (beam) is not properly built.
(3) Insulation batts are backwards with the vapror retarder facing the crawl space.
Aaron
Old 12-12-2008, 05:07 AM
Sorry I forgot:
(4) Girder (beam) not centered on top of pier.
Aaron
  #6 (permalink)
Old 12-12-2008, 10:35 AM
Jerry Peck's Avatar
Aaron,
If you are going to get into everything you see, those "soft wood shims" you see is a piece of plywood, and plywood is does not make a suitable shim.
It is much easier to make a list of what one sees correct in that photo, such as:
1)
(well, I tried to find something correct)
  #7 (permalink)
Old 12-12-2008, 10:52 AM
Rick Hurst's Avatar
Noticed that there is no termite shield installed on the pier either.
Aaron,
That infamous SE here in Dallas that we all have come to know over the years says that the girder beam does not have to be exactly centered over the pier as long as 60% of the beam is on top of the pier. Have you heard this?
  #8 (permalink)
Old 12-12-2008, 11:56 AM
Re: foundation this can not be correct
the whole foundation needs to be reviewed by a engineer. how about the bottom of the trusts not sitting on top of the top plate.
  #9 (permalink)
Old 12-12-2008, 12:31 PM
Rick Hurst's Avatar
Tim,
I agree with you. The more pics you post, the worse it gets.
The only difference is I see no need to recommend a "review" by a Structural Engineer. I just state that the foundation needs to be repaired by a Reputable foundation company familar with Pier and Beam foundations and note what I've seen.
Why have the client spend the 300+ dollars on a SE to tell them it needs repairs which you have already told them.
JMHO
Rick
FREA Home Inspector Insurance
Similar Threads
Foundation crack below beam near foundation corner Michael Thomas Structural Components: Home Inspection and Commercial Inspection 70 02-12-2009 02:19 AM
Is flashing correct at chimney? Leon Mann Roofing System: Home Inspection and Commercial Inspection 31 12-11-2008 08:33 PM
Is this ground correct? Marc M Electrical Systems: Home Inspection and Commercial Inspection 9 11-28-2008 06:32 AM
Correct construction???? JIM MURPHY Building Interior: Home Inspection and Commercial Inspection 7 08-07-2008 02:35 PM
Commercial Foundation vs Residential Foundation Wendell Swedberg Structural Components: Home Inspection and Commercial Inspection 2 07-12-2008 07:53 AM
vB.Sponsors
Ad Management by RedTyger
