Hi Brian,
You should have the editing controls over the message box (the one I am typing in right here). Do you see them? See the attached picture.
http://www.inspectionnews.net/home_i...ext-editor.gif
I'm starting to wonder if everyone does see it. I thought I had it set as a default but maybe not?
Please let em know so I can correct this.
If you do not see the editing icons then do this:
Go to your Users CP (upper left on the menu bar)
Select "Edit Options"
Go to the bottom of the page and under "Message Editor Interface" select "Enhanced Interface" in the drop-down.
While you are there make sure your "Skin" is set to "CA Evo"
