If you can not find the Spell Check button when making a post try the following:
If you are using the Internet Explorer Browser:
You should see the editing buttons like those in the picture attached.
http://www.inspectionnews.net/home_i...spellcheck.jpg
If you do not, this is what you need to do.
Go to "Quick Links" (on the upper menu bar). Click on "Edit Options".
Scroll down to "Miscellaneous Options". In the drop down menu select "Enhanced Interface".
Click "Save Changes" at the bottom.
Do you see it now?
If you are using the FireFox Browser:
You should see the editing buttons like those in the picture attached EXCEPT for the spell check.
If you do not see the editing buttons this is what you need to do.
For FireFox spell check:
Go to
Firefox - Rediscover the Web , download and install the latest version of FireFox. (2.0.0.3)
Misspelled words will be underlined with a dotted red line. Just right click on the misspelled word and select the correct spelling.
Looks like the FireFox auto updater keep your current version of FireFox up to date but does not update you to the current version.
