Old 04-27-2008, 05:03 PM
Jim Thompson Jim Thompson is offline
Hangers for floor joists
I inspected a house this past week where hangers were used to support the floor joists as opposed to the joists resting on the sill plate.
This method was only employed in one wing of the basement (under the family room) and the rest of the joists were resting on the sill plate as is common practice in our neck of the woods.
The house was built in the mid 90s and the floor joists were 2x10s spanning a distance of about 15 feet. One end of the joist were adjacent to the garage and the other end was an exterior wall.
I did find a hanger that appears to be similar to what I saw on the simpson website under masonry hangers page 142.
Have any of you seen this practice before or is it common in your area?
Any help would be appreciated.
Old 04-27-2008, 05:32 PM
Rick Cantrell Rick Cantrell is offline
Re: Hangers for floor joists
Jim
I don't have the IRC at home, but I think that joist hangers are now required.
Someone correct me if I'm wrong.
Rick Cantrell
Old 04-27-2008, 06:13 PM
Mitchell Meeks Mitchell Meeks is offline
I don't think you need to necessarily look at the code book here. It is supposed to be attached at the back of the clip to the framing member. Not on top, if it is attached at all. You would also toenail into the bracket into the lumber. Why else would the nail holes be there. With the block there, there is no way to do it.
I would suggest you look at the Simpson web site. Here is one link for the hanger. HUTF/HUSTF Heavy Duty and Double Shear Joist Hangers
Old 04-27-2008, 06:27 PM
Rick Sabatino Rick Sabatino is offline
I would not put a lot of faith in those. They appear to be hanging themselves. Does the family room look like an addition? These don't look like something that would have passed a drawing review.
Rick Sabatino
Sabatino Consulting, Inc.
Oak Park, IL
Old 04-27-2008, 07:34 PM
Rick
It doesn't look like an addition.
Here is a picture of the rear of the house.
The pictures were taken at the rear wall adjacent to the deck.
Jim
  #6 (permalink)
Old 04-28-2008, 06:31 AM
Scott Patterson's Avatar
Those look like common wood to wood hangers and not concrete to wood hangers. It also looks like they are missing several fasteners; every hole needs to have a fastener in it.
This is from the Simpson site, it shows what is needed for a CMU to wood connection. MBHA Masonry Hangers
Nothing wrong with the wood joist being connected with a hanger to the concrete wall or the CMU wall, it just needs to be done with the proper hanger and fasteners.
Scott Patterson
  #7 (permalink)
Old 04-28-2008, 07:05 AM
Michael Thomas's Avatar
Simpson's current hanger hole codes:
  #8 (permalink)
Old 04-28-2008, 07:25 AM
Those look like the simpson structural hangers to me. They have a top flange and flange on the other side to lay on top of and straddle a beam. They are typically used to support joists off of an LVL, etc. I have a few left over from a job in my garage.
The hangers are probably sufficient to handle the joist load. I have to agree with Scott that the real questions is 'attachment'. I doubt they are properly attached to the wall. There aren't any anchors showing on the face and they don't have any holes on the top flange (unless field drilled). Just laying on the wall isn't going to cut it.
847/736-9975
Markus Keller
Similar Threads
rafter hangers Lou Wissner Attic Areas: Home Inspection and Commercial Inspection 2 03-09-2008 07:29 PM
Truss joists wayne soper Structural Components: Home Inspection and Commercial Inspection 9 07-15-2007 12:17 PM
Lateral bracing for ceiling joists John Stephenson Attic Areas: Home Inspection and Commercial Inspection 3 06-19-2007 12:12 PM
Flex ducts on joists Thom Walker Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 2 06-06-2007 07:50 PM
hacked joists John Arnold Structural Components: Home Inspection and Commercial Inspection 0 05-10-2007 05:57 PM
vB.Sponsors
Ad Management by RedTyger
