Old 05-27-2008, 12:14 PM
Ryan Stouffer Ryan Stouffer is offline
Garage gap
Hello, does anyone know if this is allowed? There is about a 4 inch gap between the garage drywall and the foundation of the home. This area is open to the crawlspace. It is inside the garage. I would appreciate any input. Additionally, is the waste line for the humidifier allowed to be secured like this? Thanks.
Old 05-27-2008, 01:29 PM
Richard Moore's Avatar
Richard Moore Richard Moore is offline
Re: Garage gap
Absolutely NOT! The purpose of the "firewall" is to provide a complete fire retardant barrier between the garage and living quarters designed to delay the spread of a fire in the garage. It also serves to prevent toxic and flammable fumes getting into the home. That gap will ensure the whole house burns down very quickly! It needs to be sealed using appropriate materials and methods.
The duct tape on the condensate line isn't pretty but not something I would get very excited about as long as it is otherwise OK (slope, etc).
Richard Moore
Rest Assured Inspection Services - www.rainspect.com
Seattle, Washington
Old 05-27-2008, 03:47 PM
Re: Garage gap
Richard, thanks a lot! I appreciate the help.
Old 05-27-2008, 04:42 PM
Gunnar Alquist's Avatar
Re: Garage gap
Ryan,
Does that condensate drain go into the main waste? If so, that is wrong. Cannot drill-out a drain/waste pipe and insert a pipe into it. In addition, there are a couple of recent posts about indirect waste into the drain/waste system.
What is the circumference of a moose?
Old 05-27-2008, 05:59 PM
Re: Garage gap
Ooops! I just glanced at that photo and though the drain line was simply being supported by the duct tape rather than connected into the ABS sewer line. Gunnar is very right...that would be wrong.
Richard Moore
Seattle, Washington
  #6 (permalink)
Old 05-27-2008, 07:58 PM
Re: Garage gap
Quote:
Originally Posted by Richard Moore View Post
Absolutely NOT! The purpose of the "firewall" ...
Nooooo ... don't use the word "firewall" as it is not a "firewall" ...
It is a "separation wall" and, as shown in the photo, it does not provide the required "separation" between the garage and the living space.
As I see it, there are two choices: 1) close that gap up with at least 1/2" gypsum board; 2) go to all the expense and trouble to cover the underside of the floor above the crawlspace with 5/8" Type X gypsum board.
I suspect 1) above would be *much cheaper*.
  #7 (permalink)
Old 05-27-2008, 08:57 PM
Re: Garage gap
Ummm...you did notice I used quotation marks around the word? There was a reason for that; in this case to indicate the use of slang.
You might want to check out The “Blog” of “Unnecessary” Quotation Marks .
But...I do use the term "firewall" without the quotation marks in my reports when there are breaches. Along with an explanation of what it's for, it gets the point across. I've never yet had a client, seller or builder come back and ask me if I meant "separation wall". Of course, I also occasionally use the word "sub-panel", where appropriate. Shoot me!
Richard Moore
Seattle, Washington
  #8 (permalink)
Old 05-28-2008, 07:59 AM
Re: Garage gap
When a fellow home inspector asks:
Quote:
The reply should be as correct as possible, not some term you want to use just because you use it ...
In your reports you should also use the proper terms, but, whatever gets your rocks off ... it is your report.
Although it is unlikely to ever happen, someday a client may call and say they want that firewall you put in your report, not just a layer of 1/2" gypsum board on the garage side for separation. As has been pointed out to them by the expert witness they have retained.
  #9 (permalink)
Old 05-28-2008, 09:33 AM
Re: Garage gap
Good to see you are back to "normal" after your incident.
Richard Moore
Seattle, Washington
Similar Threads
Garage air handlers william siegel Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 12-19-2007 08:51 AM
garage floor william siegel Exterior Systems: Home Inspection and Commercial Inspection 7 10-24-2007 01:12 PM
Attached garage Clay E White Building Interior: Home Inspection and Commercial Inspection 2 08-04-2007 06:59 PM
Insulation over garage M Kelekci Attic Areas: Home Inspection and Commercial Inspection 14 07-23-2007 06:46 PM
Garage Vents Charles Smith Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 07-11-2007 09:45 AM
vB.Sponsors
Ad Management by RedTyger
