Results 1 to 10 of 10
    imported_John Smith's Avatar
    imported_John Smith Guest
    Default AC Condensor Location - This is a new one for me
    Older house with pool. AC condensing unit located about 60' from home with line set and electrical buried under ground. Thoughts?
    Default Re: AC Condensor Location - This is a new one for me
    I had the same question sometime ago.
    http://www.inspectionnews.net/home_i...-distance.html
    If I am not mistaken it is around 25 feet max before efficiency starts dropping of drastically/ Could be wrong
    Mar 2008
    Charlotte NC
    I think that might be true with a heatpump in the heating mode, but don't see any reason for A/C or heatpump in the cooling mode.
    Im not sure why someone would do this other than they dont like the look of a condensor or the noise. I saw plenty of places around the house where they could have put it with minimal visual exposure/noise. I believe the electrical is only ran in the flex (if even that once its underground, hard to say).
    At first, I thought I must be imagining things. I walked around the house several times before I finally found it (buried in a bunch of shrubbery). Also not an electrical disconnect in close proximity.
    Mar 2008
    Charlotte NC
    Was the disconnect within sight of the unit?
    Ron Bibler's Avatar
    Ron Bibler Guest
    Where is the shut off ?
    Best
    Ron
    No separate shut off, however the main panel was somewhat within the line of sight (if you removed the vegetation around the condensing unit).
    Mar 2008
    Charlotte NC
    Sounds like a judgement call, (IRC 4001.5 Disconnect in sight of equipment). I don't think I would write it up.
    Default Re: AC Condenser Location - This is a new one for me
    From the other thread:
    Check the manufactures' "long line" requirements, both horizontal and vertical separation have to be considered.
    For example, here's Carrier's requirements for residential Puron units:
    http://www.xpedio.carrier.com/idc/gr...t/llgp-2xa.pdf
    Note line lengths of up to 200 feet (100 feet away), and up to 250 feet equivalent line lengths.
