Thread: Furnace vent
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Furnace vent
    Cool Re: Furnace vent
    Appears to be B-vent hacked open. Not approved by vent mfr. and thus codes. Should have spent the few extra bucks on a draft hood connector and not ruined a section of venting.
    FYI, every single furnace I see has improper clearance to the PVC drain line.
    Corpus Christi, TX
    Default Re: Furnace vent
    Bob,
    Am I having another false memory moment or aren't evaporator coils above the heat exchangers soon to be discontinued?
    - Paul Fix
    John Stephenson's Avatar
    John Stephenson Guest
    Isn't it 1" clearance from b-vent to combustible or is there an exception for PVC?
    Where is there any B-vent within 1 inch of that PVC?
    That's single walled pipe for about one foot so it's 6". The coil mfrs put the drain right in a place where it must pass within 6" of the appliance collar. I've seen them heat stressed and leaking.
    Jeff Eastman Guest
    Single wall pipe! Duuuuuuuuuuuuuuuuuuhhhhhhhhhhhhhhhh!!!
    Is it allowed to mix single wall with double wall?
    "Single wall pipe"
    Is it?
    I appears to me that there is an interior pipe visible just above the furnace casing and also an exterior pipe which is fitting over (is the male end) of the connection with the B-Vent. What did the labeling on the left side of the pipe say? I'm not saying this is right, but it appears to be more complicated than just a single-wall segment between the and the start of the B-Vent.
    When you hack one end of B-vent off, it become single walled vent connector.
