Results 1 to 23 of 23
Thread: bathroom heater
01-15-2009, 12:12 AM #1
bathroom heater
Never came across this one. how does this heater work?
01-15-2009, 05:23 AM #2
Re: bathroom heater
Are you asking if that is a gas wall heater?
If so, yes.
01-15-2009, 06:32 AM #3
01-15-2009, 06:50 AM #4
01-15-2009, 07:25 AM #5
Re: bathroom heater
I don't like any heater/fireplace that is unvented. It dumps all the combustion product into the room along with a lot of moisture from the burnt gas.
01-15-2009, 07:26 AM #6
Re: bathroom heater
Vent-Free Warnings:
-Don't use if anyone in the house is pregnant, diabetic, anemic or suffers from heart or respiratory problems
-Cannot be used as a sole or main source of heat
-Cannot normally be installed in a bedroom or bathroom
-Cannot be installed in a "confined space" where fumes may not be properly dispersed
-Should not be installed if the fireplace or chimney is in disrepair
Vented appliances address all these common home issues. Wouldn't you really rather vent those fumes OUT of your home through a chimney or vent?
01-15-2009, 07:29 AM #7
Re: bathroom heater
I know it is gas. But how does it operate? It only has a valve that turns on the gas. No pilot light, no switch on the wall to turn it on.
01-15-2009, 08:53 AM #8
Re: bathroom heater
Likely turn on the valve and strike a match
Needs to be removed, as noted, unless properly vented.
01-15-2009, 09:07 AM #9
Re: bathroom heater
After those heaters are removed, most people convert that opening for a magazine rack in the bathroom instead of drywall repairs.
01-15-2009, 09:24 AM #10
01-15-2009, 09:29 AM #11
Re: bathroom heater
This is one of the main reasons these things should be removed. A little kid in the bathroom messing with the valve and leaves it running. The older the home the more likely it is just for an electric switch to be bad and arc when turned on or off. Not to mention they can and have been a fire hazard. Also running in a small bathroom they eat all the oxygen. I can keep going but I believe that is enough.
01-15-2009, 09:44 AM #12
Re: bathroom heater
01-15-2009, 10:09 AM #13
Re: bathroom heater
Jason,
Have you ever lit up the gas starter bar on a fireplace without the use of a wall switch?
Same principle, you need a source of ignition.
01-15-2009, 10:14 AM #14
01-15-2009, 07:23 PM #15
Re: bathroom heater
And where are those warnings from? As gas log?
The one in the pic is just old and lacks modern safety controls,
Ventless gas fired heaters with ODS have an extremely good safety record when used in accordance with manufacturer's directions.and are are allowed in most jurisdictions.
They are used in millions of homes.
01-15-2009, 08:08 PM #16
Re: bathroom heater
I wonder why gas kitchen ovens and stoves are not supplied with oxygen depletion sensors since they use as much fuel..as these kinds of heaters.
I used old heaters with ceramic plates in beautiful Webster Texas for a few winters and thought they worked great.
I've also been to more than a few homes heated with natural gas right from the well in West Virginia that burned heaters like that and never a problem..
Funny I never realized a few years later using these heaters is tantamount to child endangerment ,based on what if's and mights
Grew up burning coal .. woke up more than a few times with strong "coal gas" smell from a damper too closed. We knew more than a few deaths from that mistake.
01-15-2009, 08:23 PM #17
Re: bathroom heater
Richard, not implying you are as old as Aaron and I
but if you were using those heaters, you might be close to my generation and the leaky houses that went along with them. It was hard to keep air in there when you tried and most people of that era turned them off when sleeping so people dying of CO was less of a problem than it would be in a well sealed house of today.
01-15-2009, 08:41 PM #18
Re: bathroom heater
Because those are considered 'attended' appliances where the user is there during their use (with a few exceptions such as when something is baking in the oven for a couple of hours, no need to stand and watch it, as they say 'a watched pot never boils').
The other appliances are 'unattended' appliances.
At least that is 'my' theory as to why.
01-19-2009, 08:14 AM #19
Re: bathroom heater
Thank you for all all your input.
01-20-2009, 03:29 PM #20
Re: bathroom heater
Jason,
Is that unit installed on a wall or at ceiling?
If the bathroom's exhaust vent is wired with this heater, venting should not be a problem not that it is.
01-20-2009, 04:52 PM #21
Re: bathroom heater
Enlcosed garage heater
01-20-2009, 05:04 PM #22
Re: bathroom heater
Those types of heaters are common in many of the rural areas near me. People have no realization of how dangerous those are.
Ted, that does not look like a garage.
09-29-2011, 01:46 PM #23
Re: bathroom heater
jason did you ever find any info on the wall heater you have
