    Kevin Teitel's Avatar
    Kevin Teitel Guest
    Default High Efficiency WH discharing behind A/C unit
    This is an 11-month warranty inspection and I found that the builder put the outlet for a high efficiency water heater directly behind the A/C compressor unit. This has got to be wrong. Can anyone site a reference? Thanks.
    Kevin Teitel
    House-Pro Inspections, VA
    Richard Stanley's Avatar
    Richard Stanley Guest
    Default Re: High Efficiency WH discharing behind A/C unit
    Rough guess - code not handy. Oversized pipe terminated more than 24" above ground - dumb location choice.
    Quote Originally Posted by Kevin Teitel View Post
    Kevin Teitel
    Well, common sense would tell you that the corrosive flue gas from the water heater will eventually corrode the coils/fins on the unit. I would call it out for that reason alone.
    Here is a pretty good catch-all from a Goodman manual:
    Special consideration must be given to location of the con-
    densing unit(s) in regard to structures, obstructions, other units,
    and any/all other factors that may interfere with air circulation.
    http://www.ncweb.com/~jsbuilders/gsh%20install.pdf
    You might check the installation manuals which by definition is a code requirement.
