02-24-2009, 11:54 AM #1
High Efficiency WH discharing behind A/C unit
This is an 11-month warranty inspection and I found that the builder put the outlet for a high efficiency water heater directly behind the A/C compressor unit. This has got to be wrong. Can anyone site a reference? Thanks.
Kevin Teitel
House-Pro Inspections, VA
02-24-2009, 03:04 PM #2
Re: High Efficiency WH discharing behind A/C unit
Rough guess - code not handy. Oversized pipe terminated more than 24" above ground - dumb location choice.
02-24-2009, 04:23 PM #3
02-24-2009, 04:59 PM #4
Here is a pretty good catch-all from a Goodman manual:
Special consideration must be given to location of the con-
densing unit(s) in regard to structures, obstructions, other units,
and any/all other factors that may interfere with air circulation.
You might check the installation manuals which by definition is a code requirement.
