Results 1 to 2 of 2
    Apr 2007
    WESTMINSTER CO
    Default CLEARANCE FOR PEX PIPE AND BOILER VENT
    HEY ALL HAPPY EASTER
    is this proper, for pex pipe. that wirsbro pipe was rally hot with furnace on. any code for this clearance
    thanks
    charlie
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Re: CLEARANCE FOR PEX PIPE AND BOILER VENT
    thanks
    charlie
    CVF: From Zurn:
    Zurn PEX must be kept at least 6" away
    from the exhaust vent of a gas-fired water
    heater. This is easily accomplished by
    using flexible water heater connectors.
    When the inlet and outlet connections are
    well away from the exhaust vent, such
    as most heaters with side connections,
    Zurn PEX may be connected directly to
    the water heater.
    Running the Zurn PEX Tube
    After the manifolds have been installed and the tube size selected, the
    next step is to install the Zurn PEX tube. When installing the tube,
    there are several points that must be considered:
    1.
    Bending
    2.
    Expansion and Contraction
    3
    . Abrasion
    4.
    Heat Sources
    5.
    Friction Damage
    6. Freeze Protection
    http://www.zurn.com/operations/pexrh...sApplGuide.pdf
