Results 1 to 3 of 3
    Mar 2011
    Lombard, Illinois
    Default Gas line connection for furnance
    Saw the yellow type flex tubing connected to the furnace the tube is just above the burner. This just look wrong to me. Put have no knowledge whether this is safe and/ or code. Any help or guidance is mostly appreciated. Thanks to all that replied.
    Fidel F. Gonzales
    RELIANT INSPECTION SERVICE
    http://www.reliant-corp.com
    Chicago
    Default Re: Gas line connection for furnance
    It looks like the old brass colored type that someone probably reused. They spring leaks and are dangerous.
    Mike Lamb
    Inspection Connection, Inc.
    Mar 2011
    Lombard, Illinois
    [QUOTE=Mike Lamb;223768]It looks like the old brass colored type that someone probably reused. They spring leaks and are dangerous.
    gas hose brass.jpgMike , Thanks so much for your help and the article. Best regards. Fidel
    Fidel F. Gonzales
