Thread: Water heater in chase
06-15-2009, 05:15 PM #1
Amazing what one finds in the heat pump return chase. Water heater directly below the heat pump filter.
06-15-2009, 05:40 PM #2
Re: Water heater in chase
Looks like it is sealed off from the return air plenum with duct board.
Of course, all the edges should be sealed too, but the edges could be sealed in the plenum side.
06-15-2009, 05:46 PM #3
Metal return vent is on hinges and opens for direct access to the water heater. The water heater sits directly below the opening for the heat pump system that sits directly above. Yep, all the plenum boards are nicely sealed though. Water heater blocks most of the furnace filter though.
06-15-2009, 05:48 PM #4
06-15-2009, 05:53 PM #5
So the heater is inside the return air chase, right?
That is why the pipes, etc. are coated with dust, right?
06-15-2009, 05:57 PM #6
Yep, good dust / crud catcher. Guess it helps keep it out of the furnace.
06-15-2009, 08:17 PM #7
