Thread: Age of unit
    David Cervantez's Avatar
    David Cervantez Guest
    Default Age of unit
    Could someone give me the age of this heat/air unit.
    Armstrong gas unit Serial #8400G43077
    Thanks for the help
    Default Re: Age of unit
    Does is look 25 years old?
    If so, that "84" at the beginning may be the year.
    Does it look about 10 years old?
    Daniel Leung's Avatar
    Daniel Leung Guest
    Quote Originally Posted by David Cervantez View Post
    I think the 3rd & 4th numbers are for year, the 5th letter is for Month (A=Jan, B=Feb, C=Mar,....).
    00G = 2000 July. Please call Armstrong 1-800-448-5872 to confirm.
    Daniel,
    That's where I got the 10 year old guess from, the second two digits.
    Wasn't sure how they did their date codes, but if it was "pretty old" it may have been 1984, otherwise if "not real old" 2000.
    Jun 2008
    Delmar NY
    Quote Originally Posted by Daniel Leung View Post
    #84 is the plant where it was manufactured, #00 is the year (2000) and G is the month (July). At least that is what I have.
    Thanks for the help
    If it was me, I would be sure to tell my client that the unit is older and has basically reached the end of it expected life. In our area, units of this age should not be expected to last much longer. If this is a package unit, I give them about 8-10 years of life in our area.
    Brian Johnson's Avatar
    Brian Johnson Guest
    I have found that by typing the model and/or serial numbers into google that all the info will come to you!!! Good luck And what type of unit is this? Forced hot air furnace?
