Results 1 to 15 of 15
Thread: furnace vent material
07-07-2009, 05:58 PM #1
This is the first time I have seen this material used for a furnace vent. Its an fan assisted induced draft gas furnace. New construction. It has a reversed connection and an unscrewed connection as well.
In addition to that, I suspect this material in not correct. Is this flexible accordion aluminum wrong for use as a vent connector?
07-07-2009, 06:20 PM #2
Re: furnace vent material
John,
I believe most of the major manufacturers make a flexible b-vent now. I think Simpson calls theirs "Dura-Connect". Not a whole lot different from regular b-vent installation requirements. They need proper slope and support. The primary visual difference is the fitting at each end. Looks like there was a fitting in the pic that you posted.
07-07-2009, 06:24 PM #3
Did it have a label or any information ?
Best
Ron
07-07-2009, 06:39 PM #4
07-07-2009, 06:47 PM #5
It sure looks like this stuff.
Aluminum Ducts Flexible 4 Inch by 8 feet #302 by Lambro Industries at HardwareAndTools.com
07-07-2009, 07:05 PM #6
I think you are correct John.
Best
Ron
07-07-2009, 07:11 PM #7
John,
If you look at the pic that you posted, the corrugations appear to spiral up the material. That is typical for the Dura-Connect product and possibly the others. If you look at the pic in the link that you provided, the corrugations do not spiral but are concentric. Without actually being there, I would say that it is an approved material.
However, you mention that the upper fitting was not screwed together. Did it have a fitting?
07-07-2009, 07:16 PM #8
Gunnar,
In post # 4 above is the picture of the upper connection.
07-07-2009, 07:19 PM #9
Shouldn't the approved material be stainless steel? This stuff was aluminum. Look at the first picture I posted. Near the bottom you see a small dent. I did that with moderate pressure of my thumb. It's not steel. No way.
07-07-2009, 07:32 PM #10
07-07-2009, 07:37 PM #11
John, I think this is what you have there.
http://www.americanmetalproducts.com...20-%20ADFC.pdf
07-07-2009, 07:59 PM #12
You're on the trail there.
Here is what I found with further searching. Check page 24 of the following. It says its aluminum double wall B vent.
http://www.americanmetalproducts.com...dition%204.pdf
I'll write up the loose unscrewed connection and leave it at that.
Thanks everyone.
07-07-2009, 08:09 PM #13
John, The instructions I have also say it is aluminum (#6 in instructions). It also says sheet metal screws are not necessary.
07-07-2009, 08:58 PM #14
I'm not sure, but when they say screws are not needed, I think they mean when the connector is attached to other American Metal Products.
It is snapped in tight at the bottom to a similar product. But, at the top where is transitions to standard B-vent, the connection is loose. There is no positive connection holding it together up there. Even one screw to hold it in place would be nice.
07-08-2009, 03:23 AM #15
John,
What is the end away from the furnace connected to? Those connectors are used when installers are too lazy to use all b-vent or single wall when appropriate clearances can be met. B-vent should not be used on a draft induced appliance (non-condensing) unless its going into a working chimney properly sized for the appliance(s) with a good draft and/or liner. Greetings from rain soaked NY State. Jack
