Results 1 to 18 of 18
Thread: furnace condensate and sump pump
08-20-2009, 06:35 PM #1
Is there a problem discharging high efficiency furnace condensate into a sump, due to the caustic nature of the condensate damaging the pump?
08-20-2009, 06:38 PM #2
Re: furnace condensate and sump pump
John,
I am sure you can find a sump pump rated for all kinds of fluids, just not sure is a standard condensate sump and pump are.
Did you get the manufacturer of the condensate sump which was installed?
08-20-2009, 07:01 PM #3
Actually, I started wondering while listening to a plumbing webinar. I wasn't satisfied with the answer from the presenter because he characterized furnace condensate as "water vapor" and therefore harmless to a pump. He was saying that caustic fluids, like bleach from a laundry tub, should not discharge into a basement sump pump (of course), and I asked about condensing furnaces because I see them discharging into sump pumps all the time. Sump pumps. Not condensate pumps.
08-21-2009, 03:59 AM #4
Discharging into the sump does two things that are a negative.
1. Adds moisture to below slab.
2. Requires more electricity to cycle on and off.
A condensate pump with discharge outside the home is my preference.
08-21-2009, 04:13 AM #5
Condensate from high efficiency furnaces is slightly acidic, about the same as Coca-Cola.
Some of these furnaces will have a block of neutralizing substance in the condensate drain system. Others do not. It should not harm your sump pump if its mixing with other water in the pit.
08-21-2009, 05:21 AM #6
John, I questioned the same response as well (I was in on that webinar also) from him. I always thought that the condensate from a high efficiency furnace was corrosive as well, but after reading Ray's response I'm inclined to side with him. I have never called this out before and I don't think I will (unless someone else has more compelling evidence). Furthermore, I don't have a problem with washing machines dumping into them also (speaking here on experience).
08-21-2009, 05:51 AM #7
08-21-2009, 06:12 AM #8
I call dumping the furnace condensate into a sump a "dope slap!" There is seldom enough condensate to lift the float and activate the pump. The condensate evaporates back into the home not a bright thing to do, but convenient for installers. I also get a kick out of the homeowners who drain the dehumidifier into the sump. I always recommend that a condensate pump be installed for discharge to the exterior.
08-21-2009, 06:49 AM #9
I can't see the acidic content of condensate water damaging a typical sump pump, especially once it's diluted with water that's in the sump pit. The standard condensate pumps are fairly cheap plastic contraptions. If the condensate doesn't eat those it isn't going to eat a sump pump.
As far as energy usage from the sump kicking on, I don't see that as an issue on the heat side. Maybe on the AC side if it is also pumped to the pit but doubtful.
Besides a new sump pump is cheap.
08-21-2009, 07:41 AM #10
In one of my trade magazines there was an article about how corrosive condensate was from the condensing heaters. It showed a condensate drain that was draining into a near by floor drain for only a couple months and the brass ring for the floor drain and the concrete around the drain where badly etched.
I will try to find this article and post it here.
Ron Hasil IL Plumbing Lic #058-160417
A-Archer Sewer & Plumbing specializing in:
Tankless Water Heaters | Drain and Sewer Cleaning | Sump and Ejector Pumps | Backflow RPZ Testing
08-21-2009, 11:28 AM #11
Still cannot find the which trade magazine had the article but this post came up on the ridgid forums. Copper pipe corrosion on a condensing furnace - RIDGID Plumbing Forum, Woodworking Forum, Power Tool Forum
08-21-2009, 04:15 PM #12
08-21-2009, 04:41 PM #13
Dave,
Agree about the freeze potential, but it is all about installation details. If it's a 3/8 inch plastic hose that sticks out of the band joint then Yes, it will freeze. If it is a 3/8 hose that is run within a 1" inch PVC pipe that elbows to the ground, not a problem.
08-23-2009, 08:22 AM #14
I installed a standard condensate pump when installing my 90+ gas furnace about 8 years ago. No problems so far.
08-23-2009, 09:59 AM #15
08-23-2009, 08:33 PM #16
No the drain terminates indoors.
08-23-2009, 09:56 PM #17
08-23-2009, 10:10 PM #18
Oh, I almost forgot what I learn 45 years ago. When the Methane CH4 (in the natural gas) burns with Oxygen O2, it forms Carbon Dioxide CO2 and Water H2O (ref: Methane - Wikipedia, the free encyclopedia
CH4 + 2O2 → CO2 + 2H2O
This chemical reaction is not complete yet. If the Carbon Dioxide disolved into the water, it forms Carbonic Acid H2CO3, a weak acid H2CO3 - It is used in making of soft drinks eg. Colas, Ice Tea, Lemonade and Sparkling Water (ref: Carbonic acid - Wikipedia, the free encyclopedia
CO2 + H2O ⇌ H2CO3
Last edited by Daniel Leung; 08-23-2009 at 10:12 PM. Reason: correct the wikipedia links
