Results 1 to 9 of 9
Thread: Heat Pump vs. AC
08-26-2009, 11:46 AM #1
Heat Pump vs. AC
Recently inspected a house that had a heat pump for one level and a conventional AC unit for the remaining two levels. Just wondering why two different systems were installed by the builder. And if so what are the advantages/disadvantages to a heat pump?
08-26-2009, 11:57 AM #2
Re: Heat Pump vs. AC
Heat pumps and Air conditioning units are nearly identical in the A/C mode, it is the heating mode that the difference comes to light.
What was the heat source in the unit with A/C only? Upstairs, summer room, etc. all plays a role.
08-26-2009, 12:26 PM #3
The heat pump services the top level only (about 700 s.f) and the other heat source is a gas furnace (about 2,000 s.f.)
08-26-2009, 01:23 PM #4
Cheaper for a small heat pump system for the small second floor area. A gas fired unit would have cost a grundle. Also you need less heat on in the winter on the second floor than you do the first floor. What they should have done was zoned the first floor system they would have cut a few grand off the price and it would have been more economical to run.
08-26-2009, 02:02 PM #5
Thanks for the info
08-27-2009, 02:06 AM #6
Most of the dual zone systems I see are this way.
The heat pump units are usually physically bigger than an equal capacity AC unit. Why is that?
08-27-2009, 08:23 AM #7
08-27-2009, 10:05 AM #8
08-27-2009, 10:14 AM #9
