Results 1 to 10 of 10
    Richard Moore's Avatar
    Richard Moore Guest
    Default Cardboard supply ducts in slab
    Ok...this is new for me. 1951 rambler, on a slab (which is rare around here). The furnace heat supply ducts appear to be no more than cardboard form tubes embedded in the slab and cut out at each register opening. No signs of any coating (asbestos, etc), just a lot of dust and dirt. Normal return ductwork, through the attic. Anyone seen this before?
    Very good air flow at all registers, but it just don't seem right. Comments?
    PS...the Pergo installed over the carpet was a nice touch (and a separate issue).
    Finally, the Coleman furnace appeared to be brand, spanking new but the serial numbers don't seem to conform to anything I've seen on the various forums. Model FC85080A12DH11B, Serial # W0B7424908. Anyone able to shed some light there?
    Default Re: Cardboard supply ducts in slab
    Richard,
    Looks like a real mess.
    I've seen ducts in a slab, but only in Oklahoma and they were not cardboard.
    Seem like termites would be hazardous to your ducts.
    Pergo over shag? Who would have ever thought? I guess the extra cost for the padding just didn't make sense.
    Richard Moore Guest
    "Seem like termites would be hazardous to your ducts."...
    Probably not. I doubt that our subterranean or dampwood termites (our only common species) would find the conditions to their liking. Fire hazard maybe? But...if its been there for 50+ years?????
    Yeah, the Pergo was amusing. Like a damn trampoline in all three bedrooms. And can you say moisture barrier? Clients already knew it had to be addressed.
    Corpus Christi, TX
    Richard,
    Yup, confusing. Two things come to mind. Are you 100% sure that the ducts weren't asbestos? In the year you were dealing with it would have been perfect timing for it. It would also explain why, after 50 years in the ground they hadn't completely deteriorated.
    I have attached some links and info. I suspect they may have made the V interchangable with a 5 in the model#. You might want to give Johnson controls a call to solve this. They own the Coleman Furnace name now.
    Coleman had some serious heat exchanger problems in their manufactured home furnaces, but I don't know if it carried over to Home models. I do know that across the board, Coleman has had a reputation for handling recall notices poorly. This might be the perfect case for a referral.
    Attached Files Attached Files
    - Paul Fix
    Richard Moore Guest
    Hi Thom...yes 100% certain they were cardboard or paper, and didn't appear to have any lining or coating. Someone I trust on another forum says that they are common in his area (PA) in 50' and 60's slab homes, although usually damaged by now. I've posted another photo from a different register and you can see that these are actually in good shape (where visible), just ragged at some openings
    As to the Coleman serial number...well...see the photo.
    No installation or service stickers, but I'd eat my hat if this furnace had seen a single complete heating season, nevermind being 10 or more years old. Everthing inside and out was shiny new. Maybe they've just started a whole new numbering system? Thanks for trying though
    Corpus Christi, TX
    The model # is FC8S, not 5.
    FC8S furnace
    Hell, I'd contact them just to find out why they're screwing with the serial# system.
    - Paul Fix
    New Mexico
    I see it all the time in one of the neighborhoods that I inspect. Most are fine, but a few have collapsed under ground. It's tough to tell what's going on without a camera snaked down through them. I don't know if they were supposed to be encased in concrete originally and weren't, or if they are just stuck down under the slab. I haven't excavated one of these houses yet, but would like to see one when it is cut open.
    Connecticut
    Seen it many times. Its a mess. The cardboard deteriorates and blocks the flow in areas. I guess you could snake flex duct through but the initial designer should be shot!
    Brian E Kelly's Avatar
    Brian E Kelly Guest
    Coleman furnace was manufactured on 2/20/07 and shipped to the wholesaler on 3/26/07 to a Johnstone supply store # 098.
    Last edited by Brian E Kelly; 06-08-2007 at 05:12 AM. Reason: I have access to there upg.net site
    Richard Moore Guest
    Quote Originally Posted by Brian E Kelly View Post
    Wow! I thought you were pulling my leg at first Brian, until I saw the "reason for editing". Still not 100% sure, but I guess my hat is safe!
