    Ryan Stouffer's Avatar
    Ryan Stouffer Guest
    Default 1 inch clearance to combustibles
    Should I put this in the inspection report?
    Default Re: 1 inch clearance to combustibles
    That and the improperly connected single wall connector, and that single wall connector requires 6" clearance.
    And the improper use of foil tape on the flue pipe.
    Ryan Stouffer Guest
    In picture one does anyone know how the water heater exhaust vent should be correctly connected to the furnace exhaust vent?
    Ed Voytovich's Avatar
    Ed Voytovich Guest
    Ryan: preferred practice is to have the water heater connected to the flue using a "Y" fitting to facilitate draft. Nature and physics don't like right angles.
    Mitchell Toelle's Avatar
    Mitchell Toelle Guest
    Quote Originally Posted by Ed Voytovich View Post
    Really, you're not required to provide (and should not provide) a fix, repair or recommendation regarding how something is done or its repair (even if you're an expert in that feild). Just noting the condition in your report and why it is a deficiency and a reference to the properly qualified individuals who are licensed or certified to do the repairs. Note that if you prescribe a fix and are wrong, even a little, the client can come back to you legally.
