		Thread: heater burns gas or oil
	06-18-2007, 01:36 PM #1 heater burns gas or oil heater burns gas or oilAnyone seen a heating system that is set up to burn gas or oil (not at the same time, I assume)? I haven't seen it yet, just got a heads-up from my scheduling people.
	06-19-2007, 05:06 AM #2 Re: heater burns gas or oil Re: heater burns gas or oilAnyone? Don't be bashful.
	06-19-2007, 06:25 AM #3 Re: heater burns gas or oil Re: heater burns gas or oilI have seen a few in the past. Very simple just one furnace with two different fuel burners usually set up on different sides of the heat exchange or there are units that have the burners changeable for either fuel depending on what is cheaper to run. There are also units that burn solid fuel (wood,coal) and gas or oil combo's.
	06-19-2007, 06:39 AM #4 Re: heater burns gas or oil Re: heater burns gas or oilThanks for the reply Brian.
	06-19-2007, 07:49 AM #5 Re: heater burns gas or oil Re: heater burns gas or oilYes John, you can have a variety of dual fuel setups:
 Gas & oil
 gas & wood
 Gas & coal
 oil & wood
 etc.
 I haven't looked at them lately but coming onto the market are dual fuel heaters using bio-mass such as pellets as one fuel with the hydrocarbon for backup.
 May sound good on paper but they never have received any serious attention as a great idea. To be all things to all fuels means you sacrifice something somewhere.
 As long as they are installed in accordance with the listed instructions into a suitable venting system, it should be allowable.
 Stay cool John,
 Bob
	06-19-2007, 03:50 PM #6 Re: heater burns gas or oil Re: heater burns gas or oilYes John, I used to be in charge of taking care of one at a church. It was a steam boiler and could burn either gas or oil. I usually kept it on oil because it would burn hotter and heat up faster. The unit was large at 1,000,000 BTU. I usually would have the heating mechanic fine tune it if I was switching to the other fuel for a long period. We also have the same type boiler in our town hall.
