    Sep 2008
    so so, California
    Default Looking for info on condensing furnace.
    Looking for some useful information when /if I inspect a condensing furnace.
    Default Re: Looking for info on condensing furnace.
    About the only difference with them is that they are vented via plastic, and a drain system needs to be installed. I run the furnaces for quite some time and look for leaks-- find them quite often. Also, combustion air can be pulled from the exterior or interior/ garage. Just make sure the combustion air isn't contaminated.
    Other than that, I recommend reading manufacturers installation instructions for the major manufacturers of these furnaces.
    Hope that helps?
    A.D. Miller's Avatar
    A.D. Miller Guest
    Dec 2007
    Holladay, UT
    The biggest concern I see with these furnaces is leaks behind cover, all those places where there are pvc to rubber and clamps, traps etc.
    http://acloserlookslc.com/
    Jul 2007
    Chicago
    Unfortunately they are allowed to pull makeup air from inside, which in some modern tight homes can cause an issue.
