Results 1 to 10 of 10
Thread: Flue pipe exposed in bedroom
01-05-2010, 09:24 PM #1
I have called out similar situations like this more than once. The gas flue pipe is routed through wall and is exposed in basement bedroom. Also the flue pipe does not have fire stops where it passes through the wall and ceiling. I typically suggest that fire stops be installed and that the flue pipe be boxed in and covered with sheetrock where it's exposed in bedroom.
01-06-2010, 05:08 AM #2
Re: Flue pipe exposed in bedroom
Trent,
Also, the B vent doesn't have proper clearance to combustibles; see attached.
01-06-2010, 09:53 AM #3
Great document Darren. Thanks
01-07-2010, 05:25 AM #4
The only problem with boxing it in is the cleanout has to be accessable. Was that B-Vent or all fuel pipe?
01-07-2010, 05:48 AM #5
So you box it in and install an access door; no big problem.
Gunnar- Your welcome
01-07-2010, 06:06 AM #6
Does boxing it in make it safer? Is there any code restriction to having flue exposed in living area?
01-07-2010, 05:15 PM #7
01-09-2010, 09:16 AM #8
Hi (all) &
Not to mention that flue was painted & it may burn-off during operation and release toxic fumes into that sleeping room...
CHEERS !
-Glenn Duxbury, CHI
01-09-2010, 09:38 AM #9
01-25-2010, 08:13 PM #10
Looking at the picture my question would be if that is a B vent, is the vent coming from the wall sloped? it looks like less than 45 degrees, wouldn't that be a concern ?
