Results 1 to 2 of 2
    Jonathan Cartwright's Avatar
    Jonathan Cartwright Guest
    Default How not to do an air return
    This house used to have a floor furnace. New gas furnace was installed in the garage and the floor opening used for the air return. Looks nice until you investigate a little closer.
    Floor opening was covered and one side of the wall opening was also covered. If you did not look closely and did not remove the cover this one would be easily missed.
    I thinks that the remaining opening is not large enough for adequate airflow. Toss in a dirty filter and its even better.
    Troy Eskew's Avatar
    Troy Eskew Guest
    Default Re: How not to do an air return
    I've seen some interesting return ideas in some of the older homes here, but that beats anything I've run across. Yikes
