Results 1 to 2 of 2
03-16-2010, 11:42 AM #1
Heat pump/gas furnace temperature splits
Do we use the same standards (difference between supply and return) when checking temp splits for A/C and heat pump appliances? What about the standard for checking when there is a gas furnace provided? Should the report contain SPECIFIC temps observed?
03-16-2010, 12:41 PM #2
Re: Heat pump/gas furnace temperature splits
Regarding a gas furnace the required temp rise is listed on the data plate. Usually 40-70 degrees. When I was in Colorado in the mountains, due to the thin air, the temp rise was always just barely at the minimum.
Paul Kondzich
Ft. Myers, FL.
