Results 1 to 11 of 11
Thread: Dryer Vent?
04-02-2010, 04:17 AM #1
Dryer Vent?
I have observed this condition twice recently. Perhaps I missed something in product development that allows this type of vent material to be used for exhaust?
04-02-2010, 04:41 AM #2
Re: Dryer Vent?
I don't think you're the one that missed something, Mark.
Must be smooth walled metal, except for a short connecting piece which can be listed flex metal.
04-02-2010, 04:49 AM #3
Re: Dryer Vent?
It's a Simpson Dura-Vent single-wall flexible vent connector or similar, basically, you can use it anywhere you can use single-wall vent pipe, as for example at the furnace in Mark's picture:
Simpson Dura-Vent 4DV60 Aluminum 60 Inch Single-Wall Flex Connector with 4 Inch Inner Diameter
If in doubt if it's listed for venting a gas appliance, check the labeling.
Property speaking, you vent a furnace, boiler or water heater but you exhaust a clothes dryer: http://www.ashireporter.org/articles/articles.aspx?id=1673 ).
Flexible vent connectors are somewhat similar in appearance (the flexible pipe, not the connectors) to some brands of semi-rigid flexible transition duct, for example:
http://www.glv1995.com/?catid={4602286B-D684-41B8-8553-4BAE2545D117}#{2EBEA12A-222E-4724-94BF-054C0D02561C}
used to exhaust a clothes dryer (likely what Mark is used to seeing, at dryers), but they are different systems and listed to different standards, and you can't use one for an application intended for the other.
04-02-2010, 05:17 AM #4
Re: Dryer Vent?
I assumed from the post title that it was being used for a dryer, not as a vent for a furnace.
04-02-2010, 05:54 AM #5
Re: Dryer Vent?
Thank you for the clarification between vent/exhaust gentlemen. I did not observe any lable indicating the material was rated for venting. It simply appeared to be a 6" flexible pipe which got pretty hot. Just to CMA, should the report say ''It appears the material used for venting the furnace is single wall pipe for a gas-fueled furnace. This is a fire hazard. A qualified heating and cooling contractor should evaluate and repair or replace as necessary."? I may have an opportumity to stop by the vacant condo to re-evaluate the material to further my knowledge.
04-02-2010, 09:22 AM #6
04-02-2010, 12:51 PM #7
Re: Dryer Vent?
04-02-2010, 01:31 PM #8
Re: Dryer Vent?
04-02-2010, 04:10 PM #9
Re: Dryer Vent?
Scott,
If you look closely at the OP's pic, it's venting a furnace.
04-02-2010, 06:50 PM #10
Re: Dryer Vent?
Not that this applies to this incorrectly titled thread (which has caused a problem in answering what was asked versus what the title implied), but ...
"Similar" looking material is allowed to be used for the transition connector between the clothes dryer and the clothes dryer duct. The clothes dryer duct is required to be smooth inside, made of metal, blah, blah, blah, however, the transition connector of a maximum of 8 feet is allowed to be installed, and that is allowed to be the corrugated flexible aluminum similar to what is shown in the photo.
Keep in mind, though, that Scott's post and this post are not related to the actual question or photo in this thread, they are related to the title of the thread.
04-07-2010, 02:13 PM #11
Re: Dryer Vent?
So I'm standing around on a roof this morning, and thinking" "Man... they have managed to put some seriously moisture saturated exhaust up this one... wonder what I'll find it's venting... "
Also two good examples of why:
"#@$%#" it. I really should drag the #@$%#" thirty-two foot ladder off the vehicle and get up up on that #@$%#" roof in the #@$%#" rain and get a look at the uphill side of that #@$%#" chimney... otherwise I just know I'm gonna' miss some big #@$%#" honking hole in something, and when I disclaim that side of the #@$%#" roof the #@$%#" roofer is going to make me look like a #@$%#" idiot...."
(There. Now I can feel properly virtuous.)
