    Nov 2009
    Arkansas
    Default Coleman Manufacture Date?
    I need some help with age of a Coleman split unit. Furnace Serial #W0K5002275. AC Serial # W0H5732996. My chart says Coleman is
    first two numbers are year, second two are month, then series. ???
    Default Re: Coleman Manufacture Date?
    Quote Originally Posted by Monty Freel View Post
    Go back and check your notes, or post photos of the name/data plates.
    Coleman mfg'd, Coleman labeled, or York purchased & mfg'd Coleman name.
    Looks like Wichita Units September 2005 and August 2005 respectively
    W = Wichita
    2nd & 4th position are Third digit and Fourth digit of mfg year, respectively
    3rd position is date code month of mfg.
    The model and serial number will be located on a label inside the cabinet of the furnace. The model number will be four letters, a dash, and then six more characters while the serial number is ten characters long.
    HVAC Manufacturers - History (clickable link): HVAC MANUFACTURERS
    York UPGl HVAC Model & Ser. Nos. (clickable link): York Heating and Air Conditioning: Homeowners: Product Registration
    Check your terms, Heat Pump not A/C.
    Nov 2009
    Arkansas
    Thanks for the help. Here are the photos.
    jackt0402's Avatar
    jackt0402 Guest
    Please let me try this one out.
    Furnace--October, 2005?
    AC--August, 2005?
