    Nampa, Idaho
    Exclamation Old gas floor furnace
    I have seen these old gas floor furnaces before, but this is the first I have found on an inspection. This might be the original 1940 unit. When I turned it on it really started putting out the heat. As a was standing on the floor grill above it I started to realize that my shoes were melting into the floor grill.
    Colorado Springs, CO
    Default Re: Old gas floor furnace
    I haven't seen many floor furnaces that old. Did you recommend the floor furnace be inspected by a qualified heating technician? If not you should. There is a high likelihood there is a crack somewhere in that heat exchanger.
    Bruce Breedlove
    www.avaloninspection.com
    Nampa, Idaho
    Yes I will most definitely be recommending an HVAC contractor take a closer look.
    Russel Ray's Avatar
    Russel Ray Guest
    Probably a good 25% of my inspections involve old gas floor furnaces. Sometimes they are so big and completely take up the small hallway so that if it were on for too long, one would have to jump over it.
    Dec 2007
    Oklahoma
    I still have the scars on my leg from one of these.
    The grid on my leg is wider now than original.
